Pinch Bolt Torque setting
PeteDuke
Hi Folks
Can't believe how easy it is to adjust the chain, with the correct tools !
Despite advice that you must take it too a dealer. Its dead easy.
Bought the chain adjuster tool from Ducati Mondo - what brilliant service.
I have got myself confused with the 'torque settings' guide listed.
Does anyone know the correct torque setting for the pinch bolts please.
Pete
Hyper is 31Nm, I think the old 748 was 28Nm so you are looking for something around there. Might be called 'eccentric adjuster' or some pish in the list?
From the manual;
Rear wheel hub retaining bolt: 12x1.25 - 35Nm* - GREASE B - Sequence 1-2-1
* dynamic safety-critical point; tightening torque must be within Nm ±5%.
On the MTS they are more sensibly called "Eccentric hub tightening screw". The spec is the same.
Pinch Bolts
Thank You very much
All done..and excellent forecast for the weekend, wife and daughter will be glue to Wimbledon on telly.
Feel the need for a blast.
