Pie oven/ blasiting cabinet
sam
I purchased a suction sand blasting cabinet a couple of years ago but it did not give a sook could not take the skin off a grape. It was also difficult to see with the 12v light that was fitted as standard.
I then went out and bought a pressure blast pot thinking this would solve the problem with the poor rate of suction from the original purchase I did not have much success with this either but it was a little bit better but the nozzle kept on clogging and I got a wee bit pi$$ed off with it, it has lay in the corner ever since.
Last week a friend of mine came and pointed out where the problems were so have spent the last week scrounging and raking for parts for the conversion. I will have the blast pot finished ready for a trial tomorrow evening.
Today I have fitted two 120w halogen lights that I saw in the friendly diy store for £7.49 each result
Cut a couple of holes to fit the lights into.
Finished wiring up also earthed the cabinet for the safety conscious
Before dim and difficult to see
If nothing else works at least I will see the bits inside the cabinet
Blast pot mods, instead of the pressure coming in from the side of the neck I have welded a connector into the top which will have its own air supply instead of coming from a shared Y piece.
On the bottom where the grit or beads will come from this came out and into a T piece directly into the air flow I have tried to reduce any restriction by coming into the flow gently using two 45 deg bends hopefully this will work. This also has its own air supply. When I have it running properly I will try a shared supply and see how that works but I will also up the fitting sizes to 1/2 bsp with a larger supply to the nozzle which will also be changed to a venturi nozzle.
Dont you think the crank cases look happy in there?
I thought I had my evening planned out tonight but that has went up in smoke literally,
Finished off a job I had been doing early so decided to set up the blasting cabinet ready for tonight.
Was getting mixed results with the flow even with two compressors running this setup. I recon I need more oomph so larger compressor is needed secondly as I was blasting the cylinder head I heard a small bang I thought something had fallen over only to see smoke belching from th Henry hoover I was using for exrtacting the dust from the cabinet, they don't make things as well made nowadays, I have only had that hoover since early 1990.:mad: May have to go for a run on the bike tonight or go on the pi$$ heads or tails?
Me likey. One day I'll pull my 250 engine apart and bribe you to give it the same treatment.
(In the meantime, I'm struggling to get it running at the moment.. I'll have another go at it over the weekend, and possibly pull the carb again and see if there is an obvious problem)
Ready in time for the MacGiro ? There's a nice prize to be won in the singles category...........
You might want to cover the glass of the lamps with plastic sheet. The grit will eventually turn the glass opaque and you by back to square one in terms of the amount of light in the cabinet.
Plastic sheet is easily replaced and cheaper than new glass.
Just a thought.
Hijack alert: "There's a nice prize to be won in the singles category........... " What about the "asthmatic-V-twin-that's-survived-a-battery-explosion-and-blown-head-gasket" category? :o
Just a thought.
Thought of that but too much heat coming from the lamps thats why I called it a pie oven! thinking about setting it up at the bottom of the garden to catch the masses of people that come into the picnic area sure I could make a couple o quid selling gritty pies. The lamps are only £7.50 probably as much as a bulb.
May have been a worthwhile run on the bike last night popped doon to Hedderwick to see a mate he thinks he may know where there is a feckoff large compressor lying for a few quid fingers crossed.
The support of such a trip for the wee monza really appeals for a day trip, but I really doubt that I'll be ready and confident in it by then unfortunately. Besides, I need to be down south that weekend to pick up a new bike.
Spill the beans then Mike ;)
Ah, umm... It'll almost certainly be universally disliked around here - but those that know me won't be in the least surprised. Well... maybe slightly surprised.
Yup. Another one, same year, same colour, just 40,000 miles less than the one that I've had since 2003 :rolleyes:
Yes, no surprise Mike. I remember you extolling how much you liked the current one your. Enjoy it. :)
I think I may have just solved my air supply problem, just purchased a Hydrovane air centre 112 CFM on tap here we go.:D Only problem I will have to go to Bradford to pick it up next week. Good point it will double up as a table it is 2.6mtr long x 1mtr wide.
You just live out my fantasies you do... :p
