pick up coils/icu cable on 750ss
aircooled
I have been having an ongoing problem with the cable that runs from the pick up coils inside the left hand engine case to the igniton control units, one of the 4 wires has broken twice where the cable enters the engine, i think because the cable is so old (1992 750ss). the pick up coils are fine. I want to replace the complete 4 core cable if possible with another 4 core cable, or alterntively with 4 single core cables and then protect them somehow. I am unsure what cable would be suitable. it would need to be oil & heat resistant. has anyone done this modification or have information on what cable would suitable. all information gratefully received
many thanks frankie
It's a while now since I had an SS but as I recall there was a a cable from each pick-up, each with 2 conductors. Although I may be wrong about that. Does your bike have a single cable with 4 conductors? Two for each pick-up?
If you can post a picture of the cable showing the ends I should be able to match something up to it.
Hi Derek yes you're correct its one cable with 4 insulated wires within it, two for each pick. i think what's happened is that the outer protective cable has started to disintegrate exposing the inner wires where they pass through the engine case. the grommit that makes a seal between the cable is cutting into the wires and basically cutting them in half. Getting a picture could be a problem at the moment as the bike is at a friend's garage.
Damn. I never pay attention when this is discussed on the bevelheads list. Eventually it's common to recover the ignition wires with heat/oil resistant insulation.
Can't remember the one true answer but if you ask anyone else with a bevel twin - and an attention span - they'll know.
In the meantime, this http://www.keefeperformance.com/ might provide some inspiration.
Frankie,
Does the cable have a braid screen? Does it consist of 2 twisted pairs, with or without a screen, or is it simply 4 wires in a rubber sheath?
If it is just plain cable I have some 4 core mains cable that you can have a bit of. I also have plenty of cable with 3 twisted pairs (1 pair would be redundant). I could probably find something with 2 twisted pairs lying around and there is some of 4 core screened cable which might be the thing.
hi Derek
Outside the engine the four twisted wires are protected by a rubber sheath for each wire. Around them is what appears to be some kind of fabric sheath which has started to perish. Within the engine as the four wires go through the crank case is some kind of rubber type material. once inside the engine its four twisted wires with individual rubber sheath and with fabric type material covering ( same material that covers wires going to the alternator)
cheers frankie
OK. I'm remembering better what it looked like now. I can manage to get a length of 4 core cable with 2 twisted pairs but the cable isn't rubber sheathed nor are the individual conductors. The one I have just now has a cream coloured PVC sheath and the conductors are also pvc covered - red, green, black & white. Of course this could be ruggedised (sp?) with some black heatshrink over the outer sheath which also disguise it and heat shrink over each pair within the engine casing. I've got heat shrink as well :)
PM me your address and I'll send you a bit. If it's no good it won't matter.
Whatever cable you use be careful to keep the phase for each pick-up the same. e.g If a pick-up has a red wire and a black wire, make sure that the terminal on the pick-up that was connected to the red wire still connects to the same (red) terminal on the ECU plug with the new wire fitted. If you swap them over you will reverse the phase of the pulse from the pick-up. I believe that the ecu fires on a negative going edge, so reversing the phase will advance (or retard) the ignition timing by the width of the pulse.
Many thanks Derek
will let you know how i get on once cable has arrived should get a few more weeks of riding in before the bad weather sets in
once again thanks
Frankie
hi derek
Cable arrived yesterday many thanks, i just pulled the pick up coils off the bike, the original wires running to each pick up are much thicker than the ones you sent me, i am wondering if the new cable is robust enough, but have been unable to find any information on how much current the wires from the pick up coils carry, i am guessing it will be quite low as all its doing is sending a signal. do you think the wires will be up to the job?
I'll be surprised if they're not thick enough. At 1000rpm the pick-up is putting out 4V peak to peak and even if it was 4 or 5 times that I would expect the impedance of the ignition unit to be pretty. I would expect the current to be in millivolts.Here is an oscilloscope picture of the waveform.
