Just gauging interest. Is anyone interested in a short article on the most recent method of level sensing using a thermistor ? The actual thermistor would be the one found in most Ducati’s NTC type. It would include a basic schematic where the thermistor is powered from a AA battery and a data logger would graph the actual voltage drop as a function of time when immersed in a beaker of Petrol overlayed with actual temperature as a function of time. This would cover total immersion in Petrol to bringing back to room temperature. Replacing my own sensor and have a new one to demonstrate what actually happens in real time inside the tank. There’s no need to use a data logger and could be easily replicated with a simple multimeter measuring resistance (without a battery) or voltage with a battery. Passing a current through the device is the preferred method as it’s more likely to highlight any discontinuity in the change in resistance. In addition, a simple threshold comparator will drive an LED on or off depending on the voltage developed across the thermistor. Within the instrument this is achieved in software by monitoring the voltage level on an ADC input via micro controller. Probably something similar on internet but my basic search showed nothing much.
If zero interest then no problem.
