Standard is 15/39 I think, I never much cared for this as the engine lugs at low speed around town and needs lots of clutch dipping to make it smooth, and sixth is pointless so from the very start I had a 14t front fitted, makes the engine much livelier and accellerates better. You'll never even notice the small loss of top speed.
The reason I changed the front was simply one of cost at the time, it's about £15 for a front, whereas changing the rear may also need a a new chain and can prove pricey.
That said, if your swapping out the lot then perhaps a 15/41 combo may work with a similar ratio to my current set up( it may be 15/42 I cant remember precisely-worth checking, one down on the front is similar to three up on the back I think), when I need to replace mine this is what I'll probably do as the cost will be the same.
