Done mine on 2 Multis and my DD bike. On the Multis I used the plastikote stuff from B&Q which looked fine and on this years dd bike I had some of the Sperex wrinkle finish black lying about (used on old classics) so I tried that. Looks pretty good, though you could throw a tin of dulux of em and it would be an improvement on that drab grey. Just make sure you degrease them first and make sure theres no silicon or whatever on them and give them a rub with some sandpaper to get it to key ok. I may have used some plastic primer but I cant remember now.
PJ1 do a range of paint in various finishes. Heat resistant, gloss, matt etc and I have seen some excellent results on engines etc with it.
Fairly easy to apply and get a good result.
gotta agree with Stewart there, I've used PJ1 'Fast Black' for years. I tend to use the satin finish (looks more 'factory' than matt). no priming, no phaffing about it's brilliant, it's dotted all over the Imola (and I don't mean over-spray before any of you comment)
Brilliant stuff!!!
Theres a question about this very subject being discussed on UKMOC.
Might you not be better trying to get second hand covers that come in black?(presuming you can get some in this style) ,didn't the 620/695 have these?
...trust me, you won't need to experiement with second hand ones, my fork bottoms, callipers, rear master cylinder and even the disc carers are painted in the stuff, no stone chips, smooth finish - goes straight onto metal other paint etc. brilliant.
