Painter recommendation req'd - W.Yorks
PeteW
Can anyone recommend a good painter in West Yorks, pref in the Leeds/Bradford area? I've got a SS single seat unit that I want doing, hopefully just lacquered as I've already prepped and put a red base colour on it, though this has been applied with regular aerosol. Will there be a paint compatibility issue here?
Pete
No decent paint man will put his paint on your prepping - he'll want to start from scratch (so to speak) so that he has complete control over the job.
There may be issues with the aerosol paint & the laquer.
As RockJock states non of my spray painters would touch it unless they started from scratch. To much hassle if the paint bubbled.:eek::eek:
If you had the spec sheet for the aerosol paint then there may be a compatible laquer.
Happy hunting.:thumbs:
if you want a really top job doing on it, take it to Torch Engineering (scooter shop) in Castleford. They will send it to their painter (in Hull, I believe) and you will be very happy when it is returned.
Only ones I would trust with the paintwork for my restos.
HTH
Garry.
