Weemonster
My 98 M600 runs on one cylinder when its cold.
After about 5 miles its coughs splutters shoot fame out the exhausts and takes off. Both cylinders working.
I've changed the plugss and leads and caps and swapped over the coils because there was no spark on the horizontal cylinder.
But it doesn't matter what i do the horizontal cylinder will not fire when cold.
So i'm guessing this leaves the pick up coil or the wires to the pick up coil.
a break in the wires that closes when it heats up.
Ive yet to stick a meter on the wires but i'm guessing if theres an open circuit i should get a huge resistance
any suggestion? anything else to check/look for?
