oil strainer
jim@southwales
hi got monster s4 916 lump ,i'm doing oil change so un did oil strainer plug big allen key alloy plug .
now it looks as the strainer is still in place as it does not connect to plug
tried moving it with my little finger no way is it a case of prising it out with a screwdriver or is there a technique
please enlighten me cheers jim
The plug unscrews as you say, but so does the filter - it has a hex socket same size as the plug. Can be tight too, so needs a bit of heave ho
