oil pump condition
wheelybin
might be a bit of a no brainer, but I get better responses from DUN than other forums! but the clearance between the teeth on the gears in my oil pump are 0.2mm Service limit looks to be 0.1mm. I have had no issues with the oil pressure light, but after 10K miles, should it be this bad? I guess its best to get a new pump anyway, or is the 0.1mm a bit too pesemistic?
After 10,000 miles the oil pump should still be like new unless the bike hasn't been serviced or run with a very poor quality oil. I'd be more concerned about the clearance between the gears and the pump housing and between them and the cover. If these are within spec you are probably alright.
