Oil mist on right side
Leftus
Whilst I am not one for keeping a surgically clean engine my right side has a lot of oil misting from the base of the horizontal cylinder to the water pump cover but it's difficult to see where it is originating from, it's heaviest around the crankshaft position sensor and more around the timing sensor... do the gaskets of these sensors tend to fail over time or is there some other likely source of the oil?
Have you got any photos and what model is it? The CPS has an o-ring on its body, you could easily remove the CPS and check that. I’m not sure what you mean by timing sensor in that area and I’m presuming you mean left hand side (as you sit on it) of the engine🤔
Same thing.
Not on the 888. It has a timing sensor in front of the water pump and a crank sensor at the top of the alternator cover close to the rear of the vert cylinder. Items 11 and 14 in the diagram. Same for 851, 916 Strada and 907ie. They do have a 0-ring seal though and shims that come in 0.2. 0.3 and 0.5mm thicknesses. I've no idea where the oil is from though. If it's not from the sensors it might be from a cylinder base.
Thanks chaps, if it wasn't winter I'd wipe the surfaces and take the bike for a ride to see where the oil is issuing from, just wondered if there was a common reason...
For sale: modest sporting motorcycle collection, would consider part ex for Skidoo, fisherman's genuine Sou' Wester and or learner's skis...
