Oil grades.
Serious Black
My 93 900SS came with receipts for Shell Advance Ultra 4. As the oil was in dire need of changing I put in some Mobil1 5w50 for a while to flush any crap through. Now I'm not a fan of any particular oil as long as it is synthetic. Any preferred oils for the SS? I must admit to being on the lookout for somebody who can supply Mobil1 15w50 as I've had good experiences with Mobil1 recently. I've notice that most people go for a 15w oil, any particular reason?
Sorry about this, did a search and got nothing useful. After I posted I looked at 'Similar threads' and there was some useful stuff.
I use 15W50 fully synth. Reason, dunno really, just always have... I think John Hacket (name dropper!!) originally recommended it for my 748/853 albeit Motul 300V and at some point I drifted to Shell and just stuck with it on the SS..helps that 15W50 is the recommended grade for my parallel twin (a lesser marque..) so I buy bulk (20L drum) from Smith and Allan in Darlington. They do Shell (Advance Ultra) though, not Mobil. LOL - just read this back and it addresses NONE of your questions really.. :o
Useful info all the same, which is what I'm after. Need to find a wholesale outlet for oil here in Norway, never thought of that before. Thanks.
I hear there is plenty of Shell oil available approx 100 miles East of Aberdeen.
You might need a boat to collect it unless there is a strong Westerly wind and you should then have it on your doorstep within a couple of days! :D
Sounds like you're gearing up for the Masher humour.:eek:
spend some time on the internet researching oils and i will guarantee you . you'll know less about them than when you started out !!!!
I'd love to know the grade the inconsiderate @@@@ uses every morning on the Queensferry road - it must be one of those funny blends that actually refuses to stay in the engine.
Just once, I would like to get to work without having to ride through this tossers oil slick.:mad:
Absolutely! ;)
Change whatever you use frequently and it probably makes no difference what make etc goes in the hole.
Strange having this discussion now? Usually the subject that comes up about January time when everyone is spoiling for a fight! :rolleyes:
Strange!
When I bought the bike the previous owner told me it's history and that the engine had been torn down and rebuilt. He showed me an oil leak from the vertical cylinder that he was annoyed about. It wasn't bad so I decided to live with it until I rebuild the motor. When I changed over to the Mobil1 it looked like the leak was getting smaller, something I put down to my imagination.
Now it has gone! It's not marking it's patch like it used to. Never seen this before. Still going to pull the heads off.
