Off with her head?
hindsight
Well-known member
So, I've got the 916 on the workstand at the moment, and am bungling my way through a valve check/adj (first time on a 4v desmo head)
I've only checked the H intake so far, but it looks like both closers and one opener needs adjusted. I'll hopefully get the rest checked over the next few days when I find the time.
So - the question is: everything I read suggests that the closer shims can be done with the head in situ, but is *much* easier with it removed. For a novice like myself - should I try to do the job with the head in situ, or just be done with it and whip it off?
I'm sure it would be easier with the heads off - but have you checked the price of head gaskets :eek:
Once the cams are out there is plenty of room, although access to the vertical exhaust is a bit restricted due to the rear shock and the horiz exhaust is awkward just because of where it is.
Whether you are changing shims or not you should take the cams out so that you can check the rockers.
Any more questions just ask :)
