If a little bit snaps off and looks like a ladybird - its not, its the air pressure sensor and will cost you £50 !
Seriously take care with this bit, it is positioned in the right hand shell of the headlight casing ( as you sit on the bike ) its a bitch of a job and would suggest you have the bike on paddock / abba stand rather than the sidestand so you can get to everything and see what you are doing. Take digital camera into the garage and lots of pictures.
You will need lots of gaffa tape and a few zip ties, unless you have a good quality subframe like pierbon as the fuses and APS need a home somewhere !
It is also worth taking the bulb out of the 'nipple' light as well as it can be a distraction if it is flapping around and you see the light in your peripheral vision !
You will regognise the APS as it is in a housing that resembles a little rubber elephant trunk.
