Hi Fellas,
I need some advice on Ducati/Saprisa electric charging systems, I have a Saprisa 3 phase flywheel alternator (3 wire) two yellow wires and one red, The alternator puts out 12v AC power, I also have a Ducati energia Rectifier/Regulator which is stamped 9611 12v DC and a further number 343637, The alternator and rectifier/regulator are not an original marriage but rather parts I have brought together to serve a purpose.
As you might have suspected by now the machine is not a motorbike but its a machine that was born out of the motorbike industry, It is in fact a Howard 700 walk behind tractor, The original engine is a Villiers 28B two stroke that is rather troublesome to say the least and only to be expected from a 1960s engine.
My project is to update the machine by replacing the Villiers petrol engine with a Lombardini 6LD 435/B1 diesel engine and fitting a bonnet to house lights and protecting the engine from the elements, The rebuilt Lombardini engine was a project in itself and involved two engines going into one, What I now have is a handle start diesel engine with a flywheel alternator and electrics capability, (I did not want a starter motor)
It is the electrics I am not sure about with regard to the charging system and wiring plan, The rectifier/regulator has six wires without spade terminals and are set as:
1 Yellow 3.0mm
2 Yellow 3.0mm
3 Red 2.5mm
4 Red 2.5mm
5 White 3.0mm
6 Black 3.0mm
I assume the two yellow wires and the red wire from the alternator go to Nos 1 to 3 of the rectifier/regulator via an in line connector, I am totally stumped from there, Also all three of the alternator wires are 1.5mm, Should these be replaced with 3.0mm, The electrics I want to run on the system are 2 x single bulb headlamps, 1 x isolator switch, 1 x voltmeter, 1 x orange revolving warning lamp, 1 x 12v outlet socket to operate a small 12v kettle and 1 x fuse box, Then there is the size of battery to be considered I was thinking of 45 amp/hr but maybe I am way off on that one.
If anyone can help with input on this one it would be greatly appreciated.
Regards to all, Jimmy.
1 Yellow 3.0mm
2 Yellow 3.0mm
3 Red 2.5mm
4 Red 2.5mm
5 White 3.0mm
6 Black 3.0mm
