Cateran
Hi
Looking for opinions. I've managed to cobble together a revised brake system for the wee Guzzi (V50 II). I kept the integrated left front/rear system by relocating the reservoir and fitting braided hoses.
The single front is a combination of Venhill and Goodridge with a V50 III splitter for switch. All fine and dandy but the Master Cylinder I had lying around and inspired this redesign is off a Triumph Legend. A bigger heavier bike - my main worry was it would overwhelm the wee Guzzi's cast iron disc,
But it seems the Triumph M/C is 11mm and the original (under the tank) Guzzi was 12.7mm. Should I keep pumping or is there no way I'll get a firm feel at the lever (Giggety)?
Cheers.
Cheers.
