Nil Spark
winston
I have been having starting problems for a while now. The starter motor is fixed and working properly and last Sunday managed to get to Hartside and back, although each start got progressively worse. Now I have no start at all. Everything simple appears ok ie battery,fuses, starter relay, starter motor, new sidestand switch etc. So I thought it may be the stepper motor, which is still a possibility however, I am more inclined to think now that there may be something wrong with my coils. I've checked continuity on the engine earthing and that's ok. At first I thought it may be the coil to the vertical cylinder as I checked that before work this morning and there was no spark at both new plugs (gapped correctly). So I've ordered a new coil (£70) from DL. I've just checked the front plugs (again both new and gapped correctly) and I've no spark at those now. Is it unusual for both coils to go at around about the same time ? or could it be an earth problem at the coils ? or something a bit more sinister (ECU !!!!). For a while I am sure that it has been ticking over on just the front cylinder as idle speed has been about 700rpm recently and I've had to keep the throttle open a bit at stops. But it always revved ok and pulled ok so I am a bit perplexed. I am off work on Wednesday so intend to strip the tank off etc and have a good forage. Any ideas would be appreciated.
When the ignition is switched on there should be 12V from the fuel pump/ignition relay to each coil on the Brown/white wires. You should be able to measure this with a meter or check it with a test lamp. If no 12V, first check the relay (they are a known failure point on most Ducatis) The relay is fed by a 20A fuse and is switched by the ECU earthing it.
The ECU creates the sparks by switching the coils to earth by the Grey/Green wire to one coil and the Grey/Black wire to the other coil. If the 12V is there, you can check the coils by taking a wire connected to earth and flicking it on the Gr/Gn or Gr/Blk coil terminals. There should be a spark at the relevant coil every time you do so. You can check the ECU is switching by wiring a test lamp across the battery +ve and each of the Gr/Gn, Gr/Blk wires in turn. When you press the starter button the test lamp should flicker on and off. I don't think you'll have to dig that deep though. Good luck.
I've got a multimeter but can't do any in depth testing until I've taken the tank and seat unit off on Wednesday. Plus I've left the workshop manual at work so came to an abrupt stop tonight. Many thanks to both of you. I'll let you know how it goes on Wednesday. Wife's starter solenoid went on her Corsa car yesterday aswell ! That I have managed to test. All good fun.
Just remembered Derek. I changed that relay (a new one from DL) with everything else last week. Never checked whether or not it was duff because it was new. I'll check that on Wed also.
Oh and I just remembered, the same relay powers the fuel pump. You should hear the pump run for a couple of seconds when you switch on the ignition. If the pump doesn't run there won't be any fuel pressure and no sparks either.
Sounds like a break in a cable if everything else is ok . may have to put the meter on beep to check continuity. but take the battery off first or may GO BANG...
Without testing the relay I think it must be working because when the plugs were out , one plug and one cylinder at a time, a nice petrol vapour cloud belches out at a fair whack from the plug hole. So at least petrol is getting there. This leaves either stepper motor not adding proper amounts of air during start and warming up or no/wrong sparking. As I can't see the plugs sparking when individually resting on cylinder head I suspect sparking is the problem. Although I'm not 100% convinced as when I check earth continuity with the multimeter from the earthing bolt to the fins there is none. But when I check it to the plug hole itself there is a healthy beep. ?????? The leads are quite short so I'm limited to where I can rest a plug. The positive feed to the coils must be working cos it comes via the sidestand switch, 3amp fuse to the coils and injectors and the injectors appear to working fine as explained above. Anyway I've now got the tank and seat unit off but have had enough. Will have a closer look tomorrow as I'm on leave. Just one question. If I turn the engine over without any fuel (tank is off) to check electrickery will I do any damage ? (thinking of ecu )
Bloody 'Ell Steve you were up late. I have now checked that positive and negative is getting to the low tension connectors to the coils and everything is ok ie. there is continuity. Which now suggests that the fault lies with the coils or the leads. When I check continuity down the leads, unplugged from the coils, there is none but is this as it should be because they are high tension ? Can I check resistance and if so what figure should I be looking for ? Would it be unusual for two coils to go at the same time
Derek, having re-read your post; instead of doing a continuity check which proved ok I've now done a voltage check at the new ignition/fuel relay (by wiring direct to battery) 12volts going in but only 0.17volts coming out ??????
Can't help with correct voltages etc but just a thought.
Did you have this problem with the "old" plugs?
Reason being there was recently here a duff batch of plugs in circulation here which was causing major headaches as everyone thought that it obviously couldn't be them because they were new.
Could you try sticking the old ones back in and see if there is any difference?
Other thought is the plug leads.
They will break down with age. Could you borrow a set of leads from someone to try that?
I have had this with a car where there was mis-firing and poor starting. I put new plugs in and it was fine for a few days and then ended up as bad as ever.
Put new leads on and the car ran like a Swiss watch.
I presume the switched ignition relay is a negative contact. Checked my old one and was only getting 1.05volts from that. The old one is physically bigger than the new one and is rated 12v, 20amps and is on a 3 amp fuse to the sidestand switch. The new one (Tyco made in Portugal) is rated at 12v but doesn't give amperage. I'm becoming more and more convinced that herein lies my problem which is a bugger because I've spent two hours stripping the bike down when not necessary. I have give it a good clean though and I now know how to strip it down. I just assumed because the relay was new it would be ok but perhaps not.
I'm only round the corner if you need to swap parts about. Bring your relays and try em on my bike if you want.
The high tension side of the coil will be a very high resistance - Megohms.
I'm not sure what you mean by negative contact. The relay has 4 terminals. Two them, 85 and 86 are to the energising coil, one of these should have 12V on it and the other is earthed by the ECU thus switching the relay on. Of the other two pins, pin 30 is +12V from the fuse and pin 87 is the output from the relay. So when pin 85 (or maybe 86, I can't remember which is which) is held low to ground by the ECU the relay coil energises closing the internal contacts which link pin 30 to pin 87. Pin 87 thus provides 12V down the brown/white wire to the fuel pump and the coils.
When wired directly to the battery and then the click I am getting an output reading of 1.17v on the multimeter.
Think I might take them around to Martin's to check them both out. There's something not right cos I've put both back in one by one run the positive meter lead at the brown/white wire connector and negative to battery and I am only getting 1.47v after switching ignition on, for both relays
What are you measuring on either of the brown wires on the other pins of the relay? They should both be 12V with ignition on.
Here is a wiring diagram below if it helps. Unfortunately it's not very clear as a jpg that I can upload. No 18 is the relay. The coils are 20 and 21.
Sorry I've lead everyone up the garden path here. I was checking voltage at the brown/white terminals to the coils when it was reading very low. I have now done a two-battery check on both relays (one battery to close the relay and the other to provide a live feed) and both relays are fine with 13.4v readings coming out. So it appears to be the live feed to the relay which is very low or non-existant. The feed comes via the ecu, sidestand switch and 3amp fuse. The fuse is ok. Hence I will check the rest of the line. I bet this is going to be a corroded connector now.
Hope you get it fixed winston. I could help a lot with these leccy snags on everyones bike but as im not up to date on what does what on each bike and the diagrams then i could only guess. Not much use I know.........:o
Does anyone know where the sidestand fuse is on the Multi ? It's not where it's shown in the manual as there are only two fuses adjacent to the battery (not three as shown in the Manual). This may very well be the key to all my problems as originally I thought it was the sidestand switch so bought a new one at £55 because the 3amp fuse adjacent to the battery was ok. Looking at the coded colours having taken the fusebox apart that fuse is the ecu power supply. I've looked all over for the sidestand fuse and can't find it. Your help would be much appreciated.
Derek. It's at these brown/white wires that I'm measuring next to nowt with the ignition on. I have the diagram you posted thanks in my manual. What I can't find is the bottom 3amp fuse for the sidestand. If this is the problem I will have gone around in a full circle 'cos that's what I thought it was originally. It's all good fun.
The workshop manual shows 5 fuses at the front under the LH fairing panel and another 2 fuses just rearward of the battery but no mention of the sidestand fuse except in the wiring diagram. Oddly, the sidestand fuse is between the switch and ground. When the stand is up it should provide a ground to pin 38 of the ECU. If that ground isn't present the fuel pump and sparks are disabled. I'm sure it also disables the starter. This doesn't fit in with your symptoms of only the sparks not working.
If there is a 12V supply to the coils from the relay and no sparks then the ECU isn't switching them. One other possibility is a faulty crankshaft position sensor. If there is no signal from it the ECU wouldn't know when to spark.
Cheers Derek.
There is no 12v supply to the coils or the injectors but the starter motor is turning no problem. When you say two fuses to the rear of the battery I am a little unsure as the diagram shows three, one 20amp and two three amp fuses or am I reading that wrong (these are also listed seperately in the legend) ? You see the problem is that I have had these fuses and their support out and the coloured wire (black/grey) from the sidestand switch in the diagram doesn't exist here. Following the line through to the injectors and coils on the diagram this must be a positive feed and your previous assumptions about negative pulses from the ecu are correct. The starter motor is fed entirely seperate. In the diagram it all makes sense I just can't physically find the bloomin thing on the bike and I am now certain this is where my problem is. I say this now because I have been testing the wrong fuse before which was the 3 amp ecu fuse adjacent to the battery below the 20amp one. This wasn't apparent until I took the thing apart tonight and colour coded all the wires. Looking at the diagram again the injectors, coils, fuel pump, rear light, regulator/rectifier and horn are fed off the same line after the 3 amp fuse. I think I will try the horn.
Derek
If you chase the line from 30 (Sidestand switch) up to the 3amp fuse (marked h) and then beyond you will see what I mean. I think this line is my problem. I could be wrong though.
Winston, I would think that if the starter is turning that the sidestand switch/fuse etc is ok and the fault must lie elsewhere. I have no idea where the fuse is (I got your pm). I would be think about checking the wiring to the crank sensor, should be a connector about 18 inch up from the actual sensor. It may be worth having a look at this.
