New member - Gear Box issue!
garretjd
Hi Folks,
I am new to this forum and I wish I was just starting off with introductions but I have a problem and I hope that someone up your way might be able to point me in the right direction.
I am having a gearbox problem that's driving me mad still. I have a 2006 999s with 4k miles. Recently purchased. My first drive was short (in the rain and with an under inflated front tyre) and to a mechanic . On the journey, I don't remember issues with the gearbox or clutch but I asked the mechanic to fit an Oberon clutch slave cylinder for lighter gear change and he did. No issues. . I find that the gearbox 'bangs' into first (ie its not seamless as it used to be on previous bikes) but also up into second or third and fourth and even sometimes similar on the way down the gear change.
He swapped out the clutch plates for another set on test - no difference
He replaced some slightly warped plates - no difference
He replaced aftermarket slave cylinder with original - made it worse!
I cleaned out clutch basket and plates throughout - no effect.
System was bled - no effect. There is full fluid, no clutch slipping and no leaks.
Mechanic (who specialises in Ducati) thinks it might be gear selector forks wear - Previous owner going up and down the box without clutch. Its going to cost me €1,000 to get the gearbox out plus gear selector part costs if that's the issue, but right now we are not sure if it is!
Anyone had this problem? Any advice appreciated...or €1,000 if you have it lying around....!
Many thanks
Garret
Welcome mate, coke zero for me, stick some Bacardi Oakheart in it :)
What bikes are you comparing the gear change to and have you driven another 999 ? just a thought :eek:
Hi and welcome Garret. Your problem sounds like classic clutch drag symptoms, especially given that it didn't happen until you had the slave changed
I'd thoroughly investigate that before stripping the gearbox. My money is air in the line at the top banjo fitting
Are you having problems selecting neutral when stopped, if so I would definitely concur with clutch drag. They fitted a bleed nipple to the 1098 and later models but bleeding the master cyl via the top banjo is the only solution before that. I've had to do that with every uprated / replacement slave cyl. It's the only way to get all the air out. Cheaper too.
The 999 has a bleeder inside the clutch
reservoir it looks like the screw that holds the reservoir to the
master cylinder.
brian.
master cylinder.
brian.
Many thanks for this and the other suggestions above . Unfortunately, the master cylinder was bled thoroughly and neutral is easy to select any time. The clutch itself is behaving perfectly with bite and no drag apparent. I cannot recall if the problem was there on the test ride in the rain with an under inflated front tyre. I do not want to mess with the gearbox if I can avoid it but while the bike is drive-able and there are no alien bits in sump magnet suggesting serious issues, the problem is just wrecking my head!
I had a ppp previously and a 748. Gearbox like butter with these! the 999s is like a tractor now. G
