new head gaskets or not????
wheelybin
I have now taken the engine out of my S4, to replace the cam belt drive shaft bearings. So far so good. I took the heads off and the barrels came off with them in one piece, it did not appear to break the seal of the head gasket. Would it be safe to leave these in one piece and not replace the head gaskets? I hear they are about £90 per head, which I find hard to believe and stomach.
PS a 15mm halfords "proffesional" ring spanner with about 2mm ground off the thickness of it works a treat to get the cylinder nuts off.
What's worse Ducati no longer sell them singly. You have to buy a top end kit with all the gaskets , O-rings and seals for both cylinders at around £140! I'd definitely fit new ones though. A friend with an S4 managed to get a single gasket of a seller on eBay.
You will need one of these to re-torque the head nuts
or weld a socket in the middle of your Halfords Spanner.
When you say top end kit, does that include the base gasket?
I'll take my spanner to work and see if they can weld a socket onto it . My weldings not the best to say the least.
thanks for the advice, off back to the shed to strip more off it.
Yes it includes the base gaskets but you won't need them they are just alluminium shims that set the squish. The seal is made with 3Bond sealant.
Any one know of an engineering workshop in the borders area who would have a hydraulic puller? It looks lke this is the common method of removal of the primary drive gear.
Yes me, and a tool for torquing up the head, I'll bring them up tomorrow morning.
just been browsing through "project superspurt" makes me think an engine strip and rebuild is not an impossible task. But its harder and more involved on a ducati than it was on my old zed 750 20 odd years ago - so far.....
Crivvens - you have had a good kicking 'over there' :D
(As you said, I think it is (mostly) all well meaning ;))
I've been wondering about those extension things to get at the head nuts for torquing.
Last time I borrowed a special tool from the DOC which brought the 1/2" drive up & over to lie in line with the head nut so the torque setting was the same.
How do you compensate if using one of the straight ones like Derek showed above ?
Are there sums involved ?
http://www.engineersedge.com/manufacturing_spec/torque_wrench_1.htm
Click the "open calculator" link and just put in your variables.
Handy link but no sums required - as long as the torque wrench is at 90 degrees to the tool :)
well, in the end i ordered new gaskets, turns out, they are only :eek: £30 each!!!!!!!
Where did you get the gaskets from? When son needed 1 head gasket for his 916 earlier this year DG told him they were no longer available individually and sold him a complete top end set with all the gaskets from the cylinder base up for both cylinders at £140!
Actually it's the 907 I'm fiddling with currently. Did indeed buy an entire top end gasket set from the saintly Harold at DG.
When I fiddled with the 748 I pulled both top ends off it too.
That's a long way of saying I've no idea about single head gaskets for 916's. 907 doesn't even have any.
