Neglected Garage Monster
I have a service manual but thanks for the kind offer.
Pulled the pump and all the fuel lines out today. one of the fuel lines going from the pump to the carbs was crusted with crap inside so i've ordered all new pipes which ill replace tomorrow. I also disassembled the vacume pump as it appeared to be leaking fuel onto the belt covers below it which means it's definately not working at full capacity. The gasket inside the fuel pump had a lot of black grit around where the seal would be so i've cleaned all that up and put it back toogether.
Just a thought check the seal on the inlet manifold to make sure it’s air tight
You intending to strip/clean carbs? If so get a small/cheapie ultrasonic cleaner but let it cool between runs as they are flakie buggers.
Out of curiosity is there an electric supply to part 16, the ‘fuel pump’ or is it just running off the vacuum from the intake manifold?
Also, I presume it was pipe 13 in the diagram (post30) that was blocked which is the main feed to the carb bowls.
ps. Once a barrister always a barrister, from choice I’m just no longer registered to practice. As for dealing with ‘menial’ matters, well we all do that on a pro bono basis but most of my professional time as a lawyer was working in house for a bank on securitisations and white collar crime aka big ticket frauds. Just want to set the record straight m’lud 👍
Supporting the legality of selling debt to a third party?
Isn’t that what started off the last global financial crash, m’ lud?
No comment 🤣
Actually, I left RBS in 07, before the crash as you could see the writing on the wall, went to a ‘vulture fund’ that was set up in preparation for picking the meat off the carcass that banks like RBS and others would become. That’s when a lot of the frauds started to be uncovered 🙁
No, no electric feed, hose 9 connects to the intake manifold which creates the vacume in the pump.
And yes it was pipe 13 that was clogged.
So this is the cable mess from the battery photo at the start of the post... Weeds not included. The plug on the far right was attached to the main cable harness. everything else ran to the battery.
Can i bin the lot and plug a new headlight into the cable harness? Or is it more complicated?
Looking at your photo, was pin 85 and 86 of the relays connected to the Superseal connector far right via the red wires?
That must be the output from the headlight switch giving 12 volts to latch the relays.
What does the brown wire go to? Parking light?
Think the solution would be to source the headlight loom and restore things to OEM.
Then donate the old bulbs to Trinity House for use in a Light House.
Brown goes to the sidelight yea. Was actually thinking of using it as a headtourch.
