Need another inch
CJK
On my Monster side stand, it's got an aggressive fronty endy suspension set up,so the back has been raised a fair bit thus rendering the STD side useless unless you carry a wee dodd of wood or a spare kerb about with you.
Off hand are there any bikes I could hive a longer stand off ?
S 4r probably but pretty rare(not 100 % if it's any longer) 916 748 , can't remember how they fit to the plate on the engine casing .
Different bikes have different stand lengths as i found out when i got a trick alloy one for the Smart, its about 2 cm longer than standard :eek:
I have got a Cycle Cat longer side stand made from billet alloy, lovely thing it is that I had on my monster, I bought it from our long lost diver around £80 posted if you want it. No longer available as I think they have gone.
£80 -ouch :D
what length is it Steve ?
I read that a sports classic side stand is good swap,I'll maybe phone Harry at DG,its bound to be a relatively common thing with Monsters:confused:
I'll dig it out and measure it for you. I know they sound expensive IMIC it was somewhere around £120+ new!
They are not being made any more so they tend to go for stupid money on FleeceBay. I was hanging on to it just in case I needed it.
I have the same problem. I partially solved it by screwing a half inch thick alloy pad to the bottom of it. It could do with a bit more though.
If your stand is steel you could get a good welder to cut it and add an extra inch in the middle.
The S4 uses virtually the same frame as the ST so the stands are probably the same length, but I can measure the stand to give you an idea if it would be any better than the Monster one.
I've got an extension plate fitted to the GS stand, it just slip onto foot and was secured with a grub screw, it hasnt fallen off yet and the gs rattles a bit :D
Thanks Derek if you don't mind that would be great. Seen a few pics online of people adding bits on like youve done Michael.... I'll try getting a direct replacement first.
I got my existing stand lengthened and a new foot made up for it by the guy who did my frame and exhaust fabrication.
Seemed a fairly straightforward job.
Everything is if you know what you are doing! :rolleyes:
The ST4s stand is 9.5" from the centre of the pivot to the underside of the foot. The stand isn't straight but has a slight curve to it.
Don't even consider a stand from a pre 2000 ST. They are a horrible dog-legged thing that, as well as being dead ugly, are designed to flip up at the lease touch!
If you want it to look factory, cut it in half and weld a spacer, grind it paint it good as new. A good welder will be able to weld so nearly as strong as the factory stand.
Chris
exactly the same size :(
maybe as well getting original one modified then,it really needs done asap,I've been caught out a few times already moving it in the garage,its now on the paddock stand on the lift getting the once over :eek:
Do we know anyone on here that could do a tidy cut,add and shut ?
Hmm, as well as having a sidestand doing nowt I've got a tig welder, grinder and spray gun sitting here........... ;)
No infill metal though :rolleyes:
What is it anyway, mild steel?
think so,
betcha Eddie(ers) would do a top job,he done a top job on my SS frame which was 3/4 the way round....not that I'm doubting yer skills Eck :flash:
I don't know if you've solved your sidestand problem Colin but apparently the Hyper stand is 2" longer that the Monster/ST stands. Might be a bit much though :dunno:
yeah,it might be a bit much,an inch block of wood has it sitting perfectly.
I might do something like you've done,obviously it wouldn't be an inch pad bolted on but even 10mm might have sitting reasonably safely i took up the play on the bracket to so it should be better.
Long term I'm inclined to see how it rides being raised so far,I might compromise and lower it a tad.
Ta :flash:
if you post a pic of your stand and let me see it i will tell you if its possible in my work. if i talk nice to the boss might even get it powder coated for you to
