Multistrada Starter Motor Update
winston
Go the motor off now and it appears that one of the bushes has completely disintegrated with lots of black powder everywhere. Looks like it snapped as a fair chunk came out when tipped up. Ordered a new set which is supposed to arrive tomorrow so hopefully everything will be up and running for Saturday. I have three questions for anyone:
1. Can anybody recommend a good electrical clean spray please
2. Can anybody recommend a good crankcase gasket sealant please, the existing seems to be clear and rubber-like.
3. It has been a bit of a learning curve but relatively straight forward thus far. But as I've got my generator crankcase off and the starter motor, I was thinking that I could take some photo's drop 'em into Word and do a practical 'Idiots Guide'. If that would be of use to anyone. Everything came off with only a 5mm hex key except the wiring which needed a 10mm ring spanner. Forgot, I got a crankcase pulley made today at a local steel engineering firm (for nowt) who I do some consultancy work for, measured everything with digital verniers, worked a treat.
...what's a crankcase pulley?
...replace the starter motor gasket, if you use glupe (other than Ducati 3Bond) and it doesn't seal, you've got to do the whole job again. :)
I am sure I gave some Honda sealant gasketty stuff to someone, can't remember who but if they read this and there is any left it may be cool to share the Karma :)
I always use PJ1 industrial grade cleaner, it leaves no residue.
there are some pics of my motor and helpful replies here scroll down to reply #32 ish
There are no gaskets as such. The starter motor has a copper type gasket which is reuseable. Only a sealant between the generator case and the main body which is the sealant I need.
Can't tell whether or not your being sarcastic or not.
So I don't mean to offend by saying it works a whole lot better than levering off with a screwdriver. Needless to say there's a special Ducati tool in the workshop manual for this that'll probably cost a fortune but only took 20 mins to make whilst I waited. I did give them a CAD drawing of what I required.
The existing sealant between cases did appear to be fairly adhesive and was only about 1mm in diameter.
It's ME! Problem is -I'm in Canterbury at a conference until Friday this week -But Winston, if you want some I'm only up the road, Melling A683 if you can wait until then:) :confused:
Can't guarantee computer access either so I'll pm you my mobile - txt me if you want it:)
Of course, these days the alternator cover is wacked on with 3Bond. I still use a gasket (old bikes:rolleyes: )
I wasn't being scarcastic, I just didn't realise what you were talking about. The Ducati special tool shouldn't be needed at all, when all the studs are undone, all you need to do is give the cover a wack with a plastic hammer on the crankshaft cover (either removed or left in situ) and the alternator cover will pop the seal and come away. Then you can just pull it off. Having said that, as I said, I don't use the glupe which will have the affect of 'gluing' the cover onto the crankcase. :)
...you can still use an original Ducati starter motor gasket on the new bikes. :)
Use brake cleaner to clean the muck off.
3-Bond is the Ducati recommended sealant for the casing. If you can't get it elsewhere, I believe it is stocked by Yamaha dealers!
Your 3rd question doesn't seem to be a question :confused:
few taps with a rubber mallett and it comes off. Ducati do there own gasket goo, Ducati dealers should flog it?
Thanks for all the offers and advice. The motor is now off crankcases cleaned. New bush set completed but it was getting dark tonight and the bike is in the garage at work without lighting so I've had to leave it. Very frustrating as I was about to test the motor off the battery before putting everything back together. I'll do it tomorrow dinner.
As the sealant seemed to be a fairly strong adhesive I didn't want to whack the casing too hard hence the pulley. Have to say I am impressed at how everything has come off with no hiccups. If that had been any of my previous Jap bikes a bolt would have stripped or snapped and more often than not the very last bolt. Hope it all goes back on just as easy. There's not much torque on the casing bolts. I guess that due to improved sealant adhesives and better machining tolerances. Anyway here's to tomorrow. Many thanks
