First day abroad I lost my rear brake completely (sod's law) and have had to travel through Europe and return without it. Before I went I checked, cleaned and lithium greased the rear pistons and re-bled the whole system as I did with the front ones so it came as a bit of a suprise. On close investigation tonight it appears that the seal in the master cylinder has failed sucking air in and out. My question is can you buy the seal alone (a round rubbery/plasticky thing) or do you have to buy the whole unit ? Any help would be much appreciated.
