Multistrada 1000ds Electrics Total Failure Sorted
winston
Having studied the wiring diagram it was clear that there was a problem with the ignition as absolutely nothing worked or more importantly noting had power. All fuses were ok but the mutimeter showed no power going through the main block of five fuses. Common to all these is the live from the battery through a big round connection. On inspecion tonight one of the pins in the connection was missing with a sad corroded mess at the base of where the pin should have been. This was the red live feed direct from the battery. All the other pins were in good condition. I have now bypassed the connection for this live feed and hey presto everything is back to normal and working. Unfortunately I can't go to work on it tomorrow as my car needs an MOT. Can't wait for Wednesday though I've had withdrawal symptoms.
glad you managed to sort it, i had trouble some time back with the electrics on my 996 and turned out to several connectors looking like this
Glad to hear you've got it sorted Winston. :)
Was the corroded pin in the multiconnector?
Yes the corroded pin was in the multi-connector there are about 20 odd wires in there but only the one pin was corroded, all others appeared fine. Maybe it was the bottom of the bunch where water collected. Anyway it's now bypassed and the joints are going to be epoxied on Thursday as a precaution. I treated the remainder of the connector with ACF50. Just glad it happened at home.
I would have took photo's but I lost my diggy camera when a bag fell off the bike going up to the Orkneys in November. I am getting a Cannon A640 next week so if I have any more problems (!) I'll picture them like Steve. In a way to be honest it's probably been a good thing because I've had to study the electrics and I feel a lot more comfortable with them now even though it was frustrating. I shall now be content going to World Ducati Week. I will take some electrical spares of course.
right so that now makes you a handy man to have around at rideouts winston :p
/ian
