multi problem
rms
Hi hope one of you nice guys can help me,:D
On my way home from work tonight the bike cuts out, i pushed the starter button and the engine turned over very slowly before stopping, sort of like a low battery.After 3 attempts it turned over as normal and fired up:)
Once home i stopped and tried to restart the bike,same problem only this time its not even trying to turn over ,just getting a click from what i think is the starter solenoid, The battery was new at xmas and gets plugged in to an optimate every few days. ive also checked the ground earth [ left hand side near engine casing ]
Ive also cleaned the cable on the starter motor itself,checked fuses etc....im no mechanic :o so any help would be appreiciated
atb kev
Not sure myself but you could always try posting on multistrada.net or trawl through the archives on there.... no doubt someone will come back with some advice...:)
It's almost certainly a connection problem. Either the battery -ve to ground or the battery +ve to the bike (not to the starter solenoid). When you hit the starter button the bad connection will cause the voltage to drop so the solenoid releases. The voltage immediately rises again and the solenoid clicks in causing the cycle to start again with the solenoid clicking away.
Alternatively it may be the main relay making a bad connection and dropping out but the idiot lights would also go out or flicker along with the clicking.
Hi derek,thanks for the reply:)
checked all the above connections,i dont know if i have checked the main relay because i dont know which one it is,but i have checked and cleaned all i can get my hands to. which one is the main relay?:o
Whats happening is,turn the ignition on ,dash lights up neutral and oil light comes on, headlight on also,hit the starter and get a click ,headlight goes off, about five seconds later hear another click and the headlight comes back on.
I have also posted on multistrada.net and was told bad connection,ground etc.. was told it could be voltage regulator .
thought it might be a simple fix ,before somehow getting it to the dealers.
thanks again, kev
It's always difficult to diagnose a problem from a posting but just had another read and it is possible that the battery isn't charging and the symptoms are just those caused by a low battery voltage. If you haven't got one buy yourself a cheap multimeter. You can get one that will do the job for a tenner and it will come in handy for all sorts of things in the future.
Set it to read DC volts and measure across the battery terminals with the ignition switched off. It should read at least 12V, hopefully more like 12.5V. Turn the ignition on and see what it reads now. It will have dropped but should still be about 12V or very near to it. If it is less than 12V charge the battery.
With the battery now fully charged see if the bike will start.
If not and it still just clicks there is a connection problem somewhere. Try to establish what clicks and we will work from there.
If it does start, get the meter again and measure across the battery once more, with the engine running this time. At about 2,000rpm your meter should read about 14V. If there is no or very little increase from what it read with the engine stopped then the regulator is faulty and the battery isn't charging.
Hi derek:) thanks again for your time.
i spoke to my dealer today and described to him what was happening, was told either battery, starter selonoid or starter motor but he suspects the starter motor. and at £300 for a new one i just hope its a dud battery even though its only 10 or 12 months old.
i will take your advice and get a multimeter and do as you describe ,i will let you know the results.
atb kev
derek got a multimeter today and checked battery,
ignition off i get 12.8 v
" " on i get 12.4 v
still wont start and still getting the click noise.:banghead::banghead:
You can check whether the problem lies with the starter by bridging the terminals of the starter solenoid (the 2 copper coloured screws in the picture below) with a screwdriver or a heavy wire.
Be careful doing this because there will be sparks and a heavy current if the starter works or is jammed.
Make sure the bike is in neutral and for safety reasons I wouldn't even bother turning the ignition on.
if the starter turns the engine when you bridge the terminals then the starter is OK, if doesn't it's faulty. Simple as that.
If the starter is OK you'll have to start looking elsewhere for the fault.
:)Hi derek,just a quick update,i had a chat with the electrition at work and he told me to do what you said with the selonoid and i got nothing ,just dead , still making the click noise:mad:
So its off to the dealers on sat,told the wife we will have to live on bread and water for a while:lol2::lol2:
The trouble ive had with this bike is beyond a joke its a 54 and only done 7k, my first and last ducati which is a shame because when its running properly i love it.
i will let you know the outcome when its fixed.
thanks again for your help and advice
atb kev
It sounds like it is the starter motor then :(
I do hope that it's not your last Ducati though, I wouldn't have anything else. I love them, warts an all :D
Got an 04 plate 749 in November, put it in garage because the weather was awful. After a couple of weeks i finally got the chance to have a blast on it , DEAD AS A DODO wouldn,t start , cost 400 quid to fix two broken wires, misses was going nuts and on top of that the speed sensor gubbed up as well. Thought i,d bought a pig at that time as well but now it,s a different story - the bike hasn,t let me down since , it,s been brilliant and i wouldn,t change it for anything else (a night with Megan Fox maybe) so keep your chin up , you,ll get there with it and hopefully you,ll get the enjoyment i,m having mine .
Derek,just a quick update:)
it was the starter motor,the bike is running great again:D for now:rolleyes: £400 fitted :eek:
im due to have the stitches out after selling a kidney:D:D:D
atb....kev
Even though you think you are sorted check your regulator. I had similar problems, had a new starter fitted only for problems to return. All boiled down to failed regulator over-charging and blowing component circuitry. Cost me a lot more. I can give you a lot more detail if you need. Ducati Bury sorted my bike and it's now better than new. I also now know that Ducati had a problem with regulators and changed supplier. £82 for a regulator would have saved me best part of £1000. FYI my faulty regulator was charging at between 16.7v and 17.6v. Blew all my bulbs in addition which weren't cheap. My normal battery voltage is 13.6v and the Multi will not start at less than 12.4v. Still I think it's a great bike and was 'reluctantly happy' to invest. I bought a second-hand Honda Firestorm to tide me over and it's bland in comparison.
Motor repair
Hi,
I've had this problem several times with my monster and most advice always points towards checking connections etc which is good advice however seldon is is mentioned how to check whether it is indeed the starter motor. As the brushes wear the operation of the motor becomes intermiittent : Less contact with Commutator .
http://hyperphysics.phy-astr.gsu.edu/Hbase/magnetic/comtat.html
Sometimes you get good contact and sometime not.
NOTE: FOR SAFTEY REASON DISCONNECT THE 12 VOLT FEED TO THE MOTOR
The starter motor has a set of brushes which on a perfectly working motor should measure almost zero ohms between it's 12 volt feed and the case. Any rotation of the motor will cause this resistance to increase and then fall back to zero ohms.
I'm now on my third motor but are you aware you can purchase the brush set for around £26
http://cgi.ebay.co.uk/Ducati-Denso-...067050815_W0QQitemZ390058891763QQcmdZViewItem.
Alternatively they are available from Ducati stores.
In nearly all cases it's the brushes and they're very easy to replace once the motor is removed from the bike which is relatively straighforward as well.
MOTOR DISMANTLE:
1: Scribe Top and bottom covers with case for alignment during assembly:
2: Remove the base nut on the 12 volt terminal and take care of the insulator base and small 'O'ring.
3: Remove the two end bolts complete with 'O' rings.
4: Pull the end cap off complete with 'O' ring to reveal the brush set and support plate.
NOTE: Be careful to push the 12 volt feed terminal through the end cap as you pull off. This it attached to one of the brushes.
5: Pull the top cap off complete with 'O' ring.
6:Clean 'O' rings with propanol and spray motor assembly with brake/clutch cleaner to remove all the carbon build up from the worn brushes.
MOTOR REBUILD:
1: Insert motor assembly into case
2: Put top cap on complete with 'O' ring.
3: Place new brush set over motor pushing the brushes against their springs. One brush is already fixed onto backing plate and the other is lose which is pushed into it's housing.
4: The lose brush is connected to the 12volts feed terminal and you push this through the bottom cap.
5: Push bottom cap on.
6: Place 'O' ring over terminal and then insulator and then nut.
7: Insert the two bolts complete with 'O' rings.
That's it.
Takes around 30mins and that's mostly due to cleaning.
NOTE: EVENTUALLY WITH LOT's of STARTING THE COMMUTATOR WILL WEAR BUT THAT WILL TALE A LONG TIME BUT DOES DEPEND ON THE NUMBER OF STARTS OBVIOUSLY. ON A BIKE THAT's USED FOR COMMUTING THIS WILL ACCELERATE THE WEAR AS OPPOSED TO THE WEEKEND RIDER.
Geoff
