Monster rear wheel removal
BeePee
I've got a bit of carbon to fit and need to remove my rear wheel, what size is the socket needed ? I've seen oberon sockets for sale, are they worth the money ?
Thanks.
I'm a tool geek as well :-) pity my garage isn't as organised. Hopefully get Watty busy soon and all the shiny bits will have a new home too.
If its for the carbon hugger - apparently it can be done without taking the wheel off - the tricky bit is the holding screw on the inside of the swing arm - slim nimble fingers required or a gynaecologist friend may be helpful ;)
Andrew I'm no gynaecologist but you know the drill......I have the chain shark fin thingy to fit and there's a sneaky wee screw hiding just level with the wheel rim, bugger of a thing !
Thanks.
A much cheaper 'normal' socket will undo the nut just as well, so the answer is probably 'no'. But don't let that stop you splashing out on some bling :thumbs: :D
BTW for Oberon go to Harry @ DG - even if you pay the same price as Oberon direct at least our local dealer gets the bit between trade and retail that you would never see anyway.
Been doing a bit of googlin and think a 46mm socket will do the trick. I'll ask Harry about the oberon when I'm in later on this week. Is there a particular cable tie I should use when finishing it off ? Just kidding, I've got red ones in stock :)
Take it easy on Torque on this check book and get it bang on or slightly less
Overtighten and you can destroy swinging arm ! stretches axle !
