/ Monster - Oil Circuit
Pict
What is it that you do so as to re-circulate the oil with the oil cooler / carb heater connections blocked off? I know that there is a wee thingmyjig to take out or put in the casing just behind where the hoses terminate. Stuart must have done this on his 750?
Remove the oil cooler bypass spring, item 14 in this picture.
