jdp683
Right guys I may need some advice or pointing in the right direction.
I was out last weekend for a blast and the bike was running fine. stopped off for some grub etc and started okay and ran okay. pulled up at some lights and it cut out at low revs.
It would start with the throttle open but had to keep revving to keep it running.
Made it interesting at junctions and roundabouts!!!
Now it may be related or not but previously when started from cold it would run at higher revs until warm and it is not doing this anymore either. there is no manual choke on the new monsters.
I googled the fault and checked the vacuum hoses as per a few faults on a few monster forums and they seem okay.
Could it be an air sensor or something?
I've tweeked the tickover up just now to compensate but going away next week for a while so not using it too much in the near future.
Cheers in anticipation!!!
