Monster 695 Ecu advice
Wildman
Hi all,
After just over a year of owning my 695 I've decided I am fed up of the spit-back. On a recent ride up in the lake district the bike was a nightmare to ride as it just kept on cutting out and spitting.
It has recently been and had a full service and the mechanic (Ducati specialist) adjusted the fuel trim in order to make it richer to try and solve the problem... It now seems to have been made worse.
On the UK Monster site there is no mention (other than my own) of the issue associated with the 695 ecu and after lots of searching I found out lots on the American monster site.
I'm wondering what the best option for me in the UK would be, I can't seem to find a DP ecu anywhere, and don't really want to change the exhausts. Can another type of ECU be used such as a Dynojet or does this mean that the entire map needs to be done for the bike? I'd rather plug and play.
Any help greatfully appreciated
Tom
Possible routes you can try
1. Install a Power Commander and try the standard map for the 695.
2. As 1 but have a dyno custom map made
3 Try a reflash of the ECU to the DP map
4 Have a custom map flashed to your ECU with dyno time
I am able to do 3 with the software I have but there may be a 50 euro charge to be paid to the software creator as it is linked to the ECU serial numbers.
Below are the fuel maps for:
Standard ECU
http://www.flickr.com/photos/11884160@N06/6029656354/
DP ECU
http://www.flickr.com/photos/11884160@N06/6029102793/
Comparison of the two ie DP v Standard
http://www.flickr.com/photos/11884160@N06/6029656424/
The 695 was among the first Ducatis to be fitted with a Lambda sensor and these were well known for being too lean and spitting back. The closed loop system will not respond to fuelling adjustments and any attempt to enrichen the mixture will be seen as too rich by the Lambda which will feedback to the ECU leaning it out again.
The DP ECU is intended for an exhaust without the Lambda sensor, is hard to find and is expensive. I don't know how the Power Commander copes with the Lamda but I would imagine that's been taken care of ut they're not too cheap either.
Your cheapest and easiest option is FAT Duc O2 Manipulator which has been proven to work well in this regard.
Cheers guys, that helps alot. I think my first option is to try the fatduc jobby and get it from the USA. I'll report back my findings.
Many thanks
