Modern SS fuel tank problem
GDBD59
Member
To try & stop me waffling & making this more boring than needs be I'll try & state things briefly.
2005 SS, still under warranty.
Accident June 2006, damage included tiny tank dent (upper left side)
Repaired by accident repair place, not Ducati Glasgow.
Repaired & given brief road-test by repairer.
Bike returned September-ish.
Engine run every few weeks until now, adding small amount of fuel as necessary.
Run on road by me tonight, riding 1.5 miles for fuel. Filled up, & 14 litres or so emptied on the ground via a pipe from the tank :eek:
In the photo it's the pipe on the right from the "Y". I could understand the fault if it was a 1980's with a reserve-switch tap, but I haven't much experience of working with a modern tank, & no w/shop manual, so I'm baffled.....
I'm not too familiar with the ie model but I suspect that the drain system is the same as the carbed models.
If you look at the filler assembly you will see there is a drain hole in the recessed section to allow overflow and rainwater to drain away. On the underside of this there is a short stub which should be connected by a length of rubber tube to a similar stub at the bottom of the tank the other end of which exits under the tank to the drain hose.
It looks like the repairer has left the hose disconnected or missing.
You will need to remove the filler assembly (that can be a right pain in the @rse in itself) to replace it.
I just checked the parts list and there are in fact 2 drains from the filler recess. Sounds like one of them has come adrift. Check item 2 in the attached pic.
Thanks Derek. Makes sense. Don't understand why it's come away....unless it wasn't well fitted when made & the 'off' dislodged it....?
I won't be able to check it out for a couple of days. With it under warranty I shouldn't really be touching it, but the alternatives would be a pain in the rear too.
Gary
Hi Gary,
Just had a look at my tank and above the hoses there is an identifacation lable, the hose on the right is bleed and the other small hose is drainage.
Not sure this is any help!
Gary
SUSSED, but more advice needed
Got into the tank. BOTH rubber drain pipes were not connected to the part the filler cap bolts to. (name??) So I can only assume the repairer had it off doing the tiny dent repair & forgot to put them back on. I'll be having words...
Those of you that have been in a tank, - there are two rubber seals, the flat rubber that's exposed on the top of the tank, & a bright green O- ring further down. It looks like they've had some kind of sealer on them. I don't have any rubber grease,- would a slight smear of silicon grease be ok?
An immediate reply would be much welcome.
Ta. Gary
Hi Gary,
Good to hear you've found the problem.:)
Silicon grease will be fine. You may find it best to grease the tank aperture and not the O-ring or it may end to slide up as you push the filler assembly in.
