mis-fire
tazmanxxx
mis-fire in rear, nae cracks please lol. Whit checks kin a dae waeoot using a professional and how? Any thoughts welcomed. Duh! ;-)
Try a plug change first, since that's cheap. If the misfire still persists try swapping the coils between front and back cylinders. If the misfire swaps with it the coil is duff. If it still misfires it could be the plug lead but I think they are different lengths back and front, so you may not be able to swap them round.
Other possibles are water in the spark plug recess of the rear cyl head, loose connections particularly to the TPS/injectors, water in same connectors.
cheers oh enlightened one, will gei a' that a bash except fir the plugs as it looks like the yins that the ducati tool cannae get oot (went in wae a service) ;~)
