MHR indicator problem - its doing my head in!
900triple
The MHR is almost ready for the road at long last but for the indicators not working. Briefly...
- The bike had lain in a shed for 11 years prior to me buying it
- the indicators worked (original ones)
- I took off the full fairing and replaced it with a 900ss
- replaced the front indicators with pattern 900ss ones
- charged the battery with came with the bike and the indicators go on but dont flash
- replace the flasher unit with a new one, same as the original one
- recharge the battery and the l/h indicator blinks for about 5 secs then stays on, the r/h also stays on when the switch is flicked
- connect the battery charger to the battery and switch on the ignition but the indicators just stay on all the time depending which side is switched
- buy a new battery and charge it up. Indicators again just stay on when switched on
- start the engine and the indicators flash just as they should
- bugger
- damnation
Please help - I NEED to get this bike roaded as I am fed up looking at it beautiful as it is.
:cry:
Am no expert on electrics but if indicators work when engine is running what is the problem?
For the MOT they will test the indicators with engine running and possibly your headlight on to ensure they work ok.
Derek or some other Guru may tell you why they don't flash without the engine running but as long as they do when it is running it shouldn't be an issue.
Get it MOT'd and get it out on the road!!!;)
The world needs another bevel out there!
I took the 748 to be mot'd and there was a problem with indicators and he tested them with the engine off. The only time the engine was running was arriving and setting off (with an mot in my jacket) after I had fixed the indicators as it was the resistor that had melted that was on the wires to the indicators in the mirrors that was faulty
I think the problem is with faulty earth wires and the contacts as there is a higher current (amps) when the engine is running. You will have to check all the wiring, fuse box and connectors.
Don't know if this is one of those areas where the practice varies between MOT stations. I have had both over the years.
However reading Classic Motorcycle Mechanics in bed last night (it's an age thing!:o ) and there was an almost identical problem in a letter to the problem page. They diagnosed it as the wrong bulbs. Apparently with older bikes it is critical that correct wattage etc is used. They said that if the "new" bulbs don't match the relay then you will get this problem.
They reckoned the relay would tell you what the correct spec. of bulbs would be. Will have another look at the article to see if there is anything else that may help.
Have had another read at the article and they suggest if you can't get correct wattage bulbs to change the relay. Sounds as if you probably have the correct bulbs though.
Was going to suggest taking indicators off as no requirement for them (my bevels don't have indicators) for an MOT but B&P got there first!:D
Am putting a bike for an MOT this morning so will ask about testing with engine running or not etc. Good luck.
Oh the article is in the mag with a large feature on the MHR!!!!;) :D
There is no legal requirement to start a bike for an MoT AFAIK, they are not emmisions tested. usually they fire it up to get it to the brake tester, or if they suspect a blowing exhaust thru poor condition.
You could remove the indicator units for the MoT and pop a bit of insulation tape over the switch on the handlebar. then you're not rushing to fix it, and could even ride it :)
I had a simular problem with the Pantah after having it apart way back when. Same set up as the MHR. I found it to be a combination of flasher relay, which I took apart and overhauled (too tight to buy a new one) and a bad earth.
If they are starting to flash and then staying on or staying off - sounds like the old relay mate, even if its new, is it new 'old' stock? have you tested it? Have you got another one from a modern bike you can test as a comparison.
Its the relay that is the switch that is basically turning on and off creating the flash (as it were, stop me if I'm teaching to suck eggs). :)
The other alternative is to leave them switched off!!!! :rolleyes: :p
Are the right bulbs fitted in the indicators? 18W bulbs may not draw enough current to operate the flasher unit. It really depends on what flasher relay is fitted. When the engine is running the voltage will increase from about 12V to around 14.5V so the current drawn by the indicator bulbs will rise proportionally. A 21W bulb with 12V across it will draw 1.75A, increase the volts to 14.4V and the current increases to 2.1A. Obviously by just enough to make the flasher operate.
...good thinking Batman, to the batmobile.....
forgot about that one . :)
Do they flash fast with one of the bulbs removed?
Derek, is the maths right there?
I thought the calc was P=VI
So,
I=P/V
For 12v
I = 1.75A
For 14.4v
I = 1.46A
...yes absolutely ??????? :p
But it can be considered a resistive circuit so the cos0 won't come into it or it would be P=VICos0
And it's not 3phase in which case we would be looking at root3 as well
P=root3VIcos0
It's just a blinking indicator (or not blinking in this case).
Connect a flying earth lead from indicators to battery earth to see if dodgy earth.
So,
I=P/V
For 12v
I = 1.75A
For 14.4v
I = 1.46A
Who says the Power is a constant?
Just because the bulb is rated at 21W 12v doesn't mean that it still produces 21W at 14.5V, or at any other voltage for that matter.
W= I squared x R
so R = W/I squared
R = 21/(1.75x1.75)
R = 6.85 ohms
Assuming R is constant (which it isn't quite because it will increase a bit with temperature)and I=V/R
then I = 14.5/6.85 = 2.116A
and since W = I x V ,the bulb will be producing 2.116 x 14.5 = 30.68W
Way beyond me lads!
Anyway, like I said (or magazine said) possibly just the wrong bulbs!
Just back from MOT and asked tester about whether engine had to run or not when checking indicators etc and he said he was not aware of any specific rules on this and worked on basis that if they only worked with the engine running that was ok as long as they worked. He asked why you would have your indicators on if your engine wasn't running?
Possibly check wih MOT station before you take it there and tell them the battery is "old" and that's what Ducatis with Italian electrics do!;) :)
I have lost the will to live...
Are you sitting comfortably?
- I check which bulbs are in the flashers and there are two 23w and 2 21W
- I put two spare (original I think) 21W bulbs in place of the 23W ones
- The L/H works! Flashes away nicely if a touch slow but hey no problem and a nice satisfying click from the relay
- I try the R/H and guess what? Stays on and no flash
- Then swap the bulbs across, RH to LH and vice versa.
- the L/H stops working and the R/h flashes 3 times and then stays on, then again and this time flashes 17 times then stays on, once again and this time 6 times and stays on. - the L/H stays on and does not flash.
- I try the 23W on each side as a front back pair and they stay on without flashing on both sides.
- I try the flying earth lead and all that happens is that the relays clicks away very quickly but the bulbs do not light up.
- I have tried every other combination but the only one that works is when two of the bulbs in particular are together on the L/H side but when they are on the R/H they sometimes/partly work/some of the time....FFS
HELP!!!!
Could it be a bulb problem? Should I go for much higher wattage bulbs, higher than 23W or maybe a lower wattage? 18W say? You can see now that I have lost the plot and all my logic has flown out the window.
Maybe I should tell the MOT tester that they were only meant to flash when the engine runs - you know crap Italian electrics, they are all like that etc etc.....
My head hurts.
Maybe I should also mention that the R/H console indicator bulb is out the side which doesnt flash except when the two flashing bulbs are fitted) - the L/H concole indicator bulb works fine. Dont know if that has any relevance but you are witnessing a man grasping at straws. :beer:
I started to but by that time I hadnt the strength to turn the screwdriver as the MHR had assumed the guise of a dementor and had sucked all of my energy away. That and a thought that if the bulbs lit up then there must be a contact. But...I will summon all my reserves and give it a shot.
W= I squared x R
so R = W/I squared
R = 21/(1.75x1.75)
R = 6.85 ohms
Nice one Derek, it's all smoke and mirrors and the constant power is an old gotcha for apprentices.
Too true the resistance is the only constant noteworthy in the circuit.
Right here goes....
- Handlebar switch looks in good shape with no shorts visible
- put on the indicators and the ''working'' one takes a few seconds to get into life and start blinking then...
- the working L/H indicator is flashing about half speed I would say but...
- get this, stays on and stops blinking altogetherwhen the lights are switched on
- Connected the battery charger direct to the battery and just the same as above.
- the battery is 12AH as per the catalogues in the bike shop but the manual says 19AH - is this relevant? Is there anough juice getting to the bulbs/relay to make them work?
mmmmmmmmmmmmmmm
Don't know about the MHR but the Darmah with electric start required 26ah if not more if my ever failing memory serves me rightly ?
Also don't forget your bike has a what ? , 30 year old wiring loom and Italian spade connectors of that era came from the factory pre-corroded :eek: so it,s quite likely that a combination of high resistance connections and a possibly under powered battery is the problem . But don't give up hope what a lot of people call shoddy finish and electrics most Ducati bevel owners call character ;) :D
Paul
Maybe this won't be practical, but....if everything else works ok & it's only the indicators giving grief, would it be possible to wire relay & indicators remotely from the bike?
As basic a test as possible, with as few components/wires/connections as can be done.
You mentioned console bulbs. Article in Classic Bike (no not CMM as I said earlier....too early in the day I guess.....:o ) says high wattage bulbs that are now available can cause problems.
You have 21W and 23W fitted...or did. Article reckons the relay may be stamped to tell you what SHOULD be fitted. eg 2X21W plus 4w warning lamp etc. Have you had a look to see if there is any clue there?
Is there one or two relays? It may just be a combination of things...wrong bulbs, age of loom, poor connections etc.
I had a 12V Lucas Rita system fitted to the single and bike hardly ran worth a toot. Lucas guys said it was probably old wiring and poor connections causing the problems. Rewired bike and problems went away!
I know this is doing your head but if you can get the bike tested as long as they work when you need them you can deal with this as work in progress.
This is the least you will have to keep you occupied with a 30 year old Ducati!:)
:D See you should have taken my original advice and bought an SS and junked them like I did over 25 years ago....:comp2:
However I think bulbs are 21w earlier ones 15w so are you sure the 'new' flasher is original?
And if original worked before pulling the bike apart apart I'd put that back then try running an indepant earth from each indicator to the battery to eliminate poor earthing.
If that fails work your way through all the 'live' connections including the fuse box making sure that the point to point resistance readings are nigh on zero.
Fabulous Thread this one. I never thought that discussing bulbs would go onto two pages.....:D
Derek, I will be consulting your good self in maybe a PM or another thread with regards to a fuse problem I have with the Imola which reared its ugly head yesterday while thrashing around the best roads in the UK!
