Making fibreglass parts yourself
Dave G
I've been on the lookout for a seat unit for my SC for a while now, there are a couple available commercially but these seem to command a huge price for an unpainted part compared to what you could get for a more common model.
This has made me consider making it myself, with no experience of fibreglass moulding (other than at school which was a while ago now:shocked:) Im asking if anyone here has ever done any of it themselves.
I'd imagine laying a fibreglass part to be the easy final stage, I'm more interested in information from anyone who has made a master part and moulded it and any advice they could pass on would be appreciated.
It may turn out to be much more work than my time can handle or end up costing more than the £350+ for the basic seat I can already buy, but I'm open to suggestions here.
Essentially GRP work is very simple.
The mould needs to be made quite precisely, the finish has to be immaculate. Use a fine grain well seasoned softwood (jelutong is the best but is in fact botanically speaking a hardwood) and lots of elbow grease to establish a perfect finish, as every blemish WILL appear afterwards. It is better to make the mould by laminating separate pieces of timber together to prevent warping, don't forget to apply a "holding piece" which you can put in the vice as you lay the sheets over the mould. Finish the mould using autobody repair techniques, filler, high build primers etc to get the surface perfect. You should be able to see your reflection in the finish (admittedly maybe not the prettiest sight) as that is how the final product should turn out.
Rather than using chopped strand mat (cheaper, coarser appearance), consider woven rovings or diolen/kevlar sheets (more cost but prettier). Don't forget to eliminate "undercuts" in the mould or you won't be able to get the mould out.
Use a high grade gelcoat, self coloured if you want, lay as few sheets of mat as you can, with as little lay up gel as you can. Use a cheapy set of brushes to apply the stuff (throw away after use, saves messy cleaning up) squeegy to eiliminate air bubbles and have a reasonably warm shop to work in.
Bear in mind how and where any fasteners will be put on afterwards and design the mould to take care of that. Most of the cost will be in labour, obviously free if you are doing your own. It would be worth considering if you might make subsequent pieces (for extra sales) and it could be even cheaper.
There will be any number of self help tutorials on 't web and most suppliers of the materials will have free or cheap instructions too.
The smell when making is very intense so make sure you have a separate place to build. If you need more info give me a shout, I've done loads in the past.
Dave
I made and sold GRP fairings and seat units for Laverda triples in the mid eighties. They were based on the extremely expensive Italian Motoplast items of the time - but were made/sold at a fraction of the price!
I was self taught - using a guide offered free by one of the major GRP materials suppliers - and I was soon turning out better quality items than the professionals.
GRP laminating is not a hard skill to master. All you need is a good guide, the space to work (..it can be messy!) and the patience to do a good job. Be sure you operate in a well ventilated environment though. (..I didn't, and was as high as a kite on fumes most of the time!)
Dave
Ralph Plastics at Tranent (Macmerry Industrial Estate) should/will do anything you want in glass fibre. Ive had them make all sorts of bits for me over the years (clocky stuff though) You need a mould.
Place smells worse than BnP's farts in the morning.......best get a mask on when doing it though.
do my afternoon ones smell OK :confused:
Thanks chaps, at the moment I need to have a think about how to make the master shape and how it may be mounted etc.
I cant just copy anything I have for the bike as what I want doesn't exist on my bike, its wont be a copy of a stock part, making the basic shape doesn't phase me too much though how to finish it may be more tricky as rockjock mentions I'll need to try and make it glassy smooth and I haven't tried anything like this before so I'm less sure about that aspect.
Just how robust that master needs to be and what I make it from is something I'll need to experiment with, for the moment its just a wistful plan
What I'm looking for is a narrower seat unit more in keeping with the original 70's bikes, there are already two firms who make these but as I mentioned they are very pricey for what they are.
I'll wager that a desmosedici carbon track tail unit will be cheaper.:rolleyes::p
I was playing golf with a time served pattern maker the other day. He was old school too. The stuff he told me about was amazing. Even copied Ping putters when they first came out.
Shame skills like this are on the wane nowadays. :(
polystyrene foam and car body filler is one way to go for the plug , I think it's a form of expanded foam that is used , easy to shape with a sureform tool and sandpaper then covered in a skim of body filler rubbed down to get the best finish . You then make the mold from the plug .
Paul
