M900 Alternator Rotor Removal;
DrD
Had a search through the forum and web and not convinced about what I read - eg pieces of metal (pennies etc) between starter gears - mine work fine and I want them to stay that way.
So what is the issue:
Seems my M900 has thrown another hissy-fit
- I have return on gear lever when changing up down but not down
Drained oil (it was going to be done this month anyway)
Side casing off
Spring on the dog leg is ok but the one behind the adjuster seemed to be deformed
- the "Shift Shaft Centering Spring"
- I have now loosened the selector arm retaining bolts and spring arm fell away.
Now as I have never had the rotor off nor the tools to do it (Torque wrenches up to 140Nm - need 205Nm for this
Is there any advice on how difficult this is to replace that spring
Tools I am going to need:
Obviously going to need bigger Torque Wrench
The 88713.0710 equivalent eg DUCATI Alternator Tool Pt No. 88713.0710
- http://www.ebay.com/itm/DUCATI-Alter...-/111002568049
Parts
- new washer and nut for rotor
- new retaining bolts and washers for selector arm
- and the blasted spring
- anything else that may as well be replaced while in there
----- eg the other spring on the selector arm?
Once you've got the rotor and flywheel off replacing the spring is a piece of p!ss. I had to do the one on the ST4s. There won't be any harm in replacing the other spring and make sure you loctite the rotor nut.
Thanks - its the rotor I am going to struggle with - may get local shop to do this little bit as helicoil needed in few of casing mount threads too.
I'll decide once all the parts have arrived from Ducati Leeds.
