Loose Clutch Throwout Bearing
eonan
I've just bought a new clutch pressure plate (EVR), and a new throwout bearing (Ducati Part). The bearing fits into the plate alright, but its not a tight fit...in fact turn the plate upside down and it falls out.
So my question is this...does that bearing have to be firmly wedged into the plate (the way it was in the previous plate when I had to drive it in)? Surely it does, otherwise the push rod will simply pull the bearing out of the plate, no? Or am I completely misunderstanding how it all works (highly likely mind :o).
Cheers :)
nah it shouldnt matter
as the 6 springs from the clutch will push it all together
you can get some sort of bearing sealing paste stuff or sumit
for holding bearings in worn shells
