I want to replace the AGM battery in my '93 900 Superlight with a lithium-ion battery & would like to hear your thoughts on what I have read. After looking into this alternative, it seems that there are a few things to consider.
First, the rectifier/regulator should be able to fully charge the battery without overcharging. Next, a battery with BMS technology is preferable. And finally, some lithium-ion batteries require the use of the manufacturer's proprietary charger.
With that in mind, I would appreciate your thoughts, as well as your specific battery recommendations. Thank you so much.
