Ducati LED Indicator Conversion
The following is an account of how I carried out the LED conversion to the rear indicators on my ST4s.
I’m a great believer in LED lighting mainly because it is more reliable than incandescent bulbs. This is particularly important in the case of single bulbs stop/tail lights. I have also converted the taillight but will cover that in a separate article if there is sufficient interest.
The LEDs I have used are available from
http://www.goodwillsales.com
and are 10mm Waterclear yellow 13,000 mcd. They come supplied with resistors to run 1 LED off 12V and look like this;
The LEDs have a forward voltage (Vf) = 1.8 – 2.4V so I chose to use 4 of them in series which gives a total Vf = 9.6v (4x2.4)
So I needed to use a series resistor that will drop 2.4V assuming a supply voltage of 12V, although in practice it is more likely to be around 14V when the engine is running.
The supplied resistors are 470Ω, connecting 3 of these in parallel gives 156Ω. This under runs the LEDs slightly but will help with reliability.
This is the circuit I came up with:
Construction
For the back panel to mount the LEDs on I used 3mm Perspex sheet, simply because that’s what I had available.
Any non-conductive material would do but Perspex is easy is to work with and where the light housing has a reflective silvered background will allow light to be reflected forward from the back of the LEDs. In retrospect 2mm sheet would be better as it will allow the lens cover to fit more snugly. I found that there is a small (approx. 0.5mm) gap between the housing and the ridge on the lens.
I cut a piece of Perspex at 58mm x 42mm and radiused the ends to fit inside the housing and bored a hole to accommodate the screw fixing post so that the panel fitted snugly against the lip on the inside of the housing. It is most important that it is a good fit or (as I found out the LEDs will come loose with vibration). I then drilled 1.5mm holes at the appropriate spacings to hold the 12 LEDs and 2 resistors required and ended up with this.
I then glued all the LEDs in position making sure that they were all the same way round. i.e. all the anodes on the left.
I then twisted the wires together on the back and soldered them for a series connection. Next, the resistors were fitted and soldered in.
For the connectors to the wires I used spade terminals from and old TV SCART cable. Each terminal was bent at right angles across the broad part at the bottom, epoxyed to the to the back of the Perspex and soldered to the wires from the LEDs at each end leaving a tab that the wire spades could push on to.
This is the rear view of the final result:
Front view:
Lit up:
Complete:
To get the right flash rate you will need a couple of load resistors, one for the LH flashers and one for the RH flashers. Ducatis use 10W bulbs, so for each side that’s a 20W load.
So the current they will draw = 20/12 ( I = W/V ) = 1.67A.
To achieve this you will need a resistor of 6.8 Ohms (R = I/V) rated at 20W
( W = I2 x R)
These ones form Oberon should do nicely -
http://www.oberon-performance.co.uk/acatalog/LED-Resistors.html
You could use an electronic flasher unit designed for use with LED indicators but the resistor is cheap and simple. Just be careful where you mount them because they can get quite hot.
The circuit below shows where the load resistors should be placed in the bike’s wiring:
The basic block or 4 LEDS and their series resistor can be put together in any combination to fill an indicator light a tail light or anything else. Tail lights though have the added complication of requiring 2 circuits, stop & tail, with different brightness levels. I’ll cover those at a later date.
