Leaking Tank...Help Needed (Again)
OK, there’s another huge pool of petrol from last night, again dripping down from that seam. On closer inspection the fuel line at the point shown by the arrow is soaking.
Any ideas what might be causing it?
DG had to put a longer fuel line on there to clear the loom, so is there a chance that the outlet has been accidently damaged in some way?
If it was just coming from the outlet then surely the paint wouldn’t be bubbling like that? So could it be something on the inside? How in hell would I begin trying to fix it?
The tank has been sitting up on its stand for 10 minutes now, and the fuel line soaking down to here now...
Looking at the photos and your description it does sound more like the fuel line (housing/joint) causing this, can you remove it/them and have a look?
I'd just blame DG and sue the pants off them!!!! :D
Alternatively you could go out and buy a alloy, plastic or carbon tank.
The point I didn't make Niall about the LR tank going was that petrol spreads all over the place when leaking making a leak seem so much worse. I tend to agree with Freak - let us know.
I've sent the photos to DG for them to take a look and see what they think. I didn't want to be poking my big sausage fingers in there and potentially make things worse until they got back to me.
Niall, I am sure no expert but have had leaking fuel taps on the older bikes. Is your outlet screwed into the tank? If so presumably you will have (or should have) a washer between the outlet and the tank. If that is missing/damaged or outlet not tightened enough you would get these symptoms.
There was no washer!!!
I've drained the tank and am taking it down to DG tomorrow...I just don't have the time to be faffing around with it. Hopefully they'll be able to say for sure what what causing it.
While its off I want to get the hinge braized. Anyone know anyone?
Then I'll take it over to Rae at Brooklands to fix the paint damage.
Usually a fibre washer is what goes on the older bikes but suppose a rubber one may be ok as well. But if no washer then it WILL leak if outlet is screwed in as petrol runs down the threads and out the at the joint. This would spread along the bottom of the tank probably causing the damage you have to the paint and also soak the fuel pipe. The more fuel in the tank the worse it will be. This is a real p!sser but perhaps it's not as bad as you had feared. I would stick with the tank you have rather than start again with another. Forget the exact history with the bike but if the tank was ok before you started the project it shouldn't suddenly leak because you painted it. Good luck.
Does anyone know of the product "petseal"...seems to be a fibreglass resin, that you slosh about to create a tank within a tank...
http://www.mandp.co.uk/productInfo.aspx?catRef=501102
Any opinions as to what I should use, this or POR-15?
TIA :)
Petseal has been around for years.It is a resin sealant as you say but I wouldn't bank on it staying stuck to the inside of the tank.
I reckon the POR15 kit is much better. The kit includes a metal cleaner and rust converter/stabiliser to be used before applying the sealant. The sealant sticks really well and remains slightly flexible. So even if the tank flexes at the hinge point the sealant won't crack and leak.
As mentioned before I used Petseal on my tank last year - hasn't leaked since, so it's thumbs up from me - DG should have it in stock.
Nae worries...
Its a tricky operation - make sure yo mask the outside of the tank otherwise the vapours will stain your nice new paint-job. And (this goes without say) do it in a well vented space - unless you want to get high for a whole day and have a stonking headache for a day or so after......
gies a shout if you had any queries...
Al
