Leaking rear Brembo caliper- Seal Kit?
AndySPS
Rearbrake siezed on Sat . Cleaneda and changed pads but heat has damaged piston seals I think as there seems to be a slight leak fron the pistons . Does anyone know if an overhaul kit including seals is available and where ???
Or am I just as wel to replace the caliper?
Just in case you don't find an answer on here, someone who will be able to tell you everything there is to know about all things Brembo, is the 'Brembo' guy (sorry can't remember his name) at GPR - 08701 600950. He's the guy that Harry at Ducati Glasgow always turns to for anything Brembo related.
Thanks to all . Finally got whole caliper ( £57 all in _ why refurbish!) from PDQ motorcycle developments who had one in stock . All of the above were very helpful people but out of stock . Cheers again .
Andy
