Hi
My recently acquired 250 Mk3 - yes, 1975! - has a Dell'Orto carb which allows fuel to flow through it when the engine's not running. Unless you shut off the patrol tap (and that's not as easy as it sounds!)
Now I was warned about this from a couple of sources, like it's something you just have to accept (ffs!) But the carb has a float so surely the float needle or seat must be worn or damaged or the float itself is leaky. Surely it can't be meant to be like this!
Any help or guidance much appreciated.
