Leaking 998 tank
molenz
Hi, the yella 998 was sitting for a while, I noticed petrol seeping out the tank, got the new o ring for the fuel assembly, correctly fitted, aye Vaseline too. Still leaking, any ideas thanks. Molenz
O.k. Found out a few wee tiny holes in the tank just outside the pump assembly towards the seat, so next part how do I sort that, thanks again . Molenz
Sounds like your bike might have been sitting for too long in the garage with the tank half full. With changes in temperature condensation forms on any cold metal and this includes inside the tank The water runs down and collects at the bottom causing it to rust and it eventually creates holes. This is why it is recommended to store your bike over winter with the tank brimful.
A blocked filler cap drain can lead to the same problem. Instead of draining away, any rainwater runs into the tank when you open it.
As I see it you've got 3 options:
1. Buy another tank.
2. Have it professionally repaired which will probably involve de-rusting the tank, filling the holes with braze or maybe solder, then repainting it.
3. Try a tank sealer like POR-15. I've used this myself with good results but it is tricky to do right. If it doesn't work you could resort to one of the other options.
