Layshaft bearing help
ian900ss
Ok so the engine rebuild is going reasonabky well, until I came to the layshaft bearing on the LHS case, it wouldnt fit into the bearing as its 20mm across and the bearing is 17mm. So on investigation it appears the ST cases have a smaller bearing recess, I have put in a 6003 instead of a 6004. There is no bearing I can find thatll fit so I either turn down the layshaft??? Or buy one for an ST??
Roller on rhs ball on left. The more I think about it the more I am inclined to think the layshaft needs changed
Well, you'll be moving it towards the later spec. Funny how one thing leads to another. You'll end up with a whole new engine ;)
It appears so. I can give you a pdf copy of a 2001 900SS manual if you'd like. It should be useful for re-assembling the bottom end.
Yes please Derek. Have a look at these, I was sure I had an alternate one and hunted and found another layshaft that I had got with box of random bits I had bought recently. So the top is original, the bottom is the later version I guess. Suffice to say it fits! It looks like there is 2mm difference in the length between where the shoulder is and the other side but this is offset by the bearing being 10 not 12mm wide on the original, so I think it should be fine? Might have to cut the end off with the notch? What you think Derek?
