Italian Electrics
Cisco
Just got back from the Northern Run, bike is running great, but next day I've lost the headlights...
..put it down to the relay and replaced same but no joy. In the end had to get the wiring diagram out and.. eventually (4 hrs later) found the cause..a broken/corroded wire connection at a three way splice deep in the main loom where it passes the headstock.
Thing that got me was that the wire colours and the wiring diagram are different...and I found a couple of other splices (solder/heat shrink connections) that looked dodgy on my journey thro the loom. WTF Ducati.
This was my first big trip into Italian electrics and tbh in the days of traction control etc. I was shocked :rolleyes: at the poor quality of the loom manufacture.
Need to go and make sure my breakdown insurance is up to date....still a brilliant bike though ;)
Take care,
Frank
Sounds more like where a alarm has been fitted or removed. Had similar on my ol' 996. I removed the Meta system alarm as it wa causing loads of grief. The black wires were spliced into the loom and soldered in and heat shrinked. I ended up cut out an inch at a time the original wiring till I got to uncorroded copper to add new lenghts of wire too.
I found some hideous splicing and soldering on all my earths near the battery. The bike wouldnt start. The wires were twisted together with a blob of solder on them to stop them coming apart. It took Brian about 3 hours to sort it all. :mad:
You may just have answered me a question or saved me money or both Cisco,
My headlights have been @@@@e for several years. I've had them to bits and cleaned all the lenses, bought new bulbs and still the high beam wouldn't light up a birthday cake.
Was going to replace the relay next...but having read your post I might not bother...
That's where I'm stuck. Where do you go next to sort lights that are working but very dim........bar completely round the bend :banghead::dunno::banghead:
Guido,
To find out how good your lights really are, just get a fully charged car batttery and connect directly to your lights, then connect back to the bike system.
You will then see how much your bike system (such as poor earths/connections) is robbing you, or not, as the case may be.
You'll need a spare connector and some wire but would be pretty easy to do.
Take care,
Frank
Hmmm, not rart good with this electrickery but will have a look and see what I can find/completely fook-up.
Thank a million for the tips tho chaps.
I will be able to see the next bend after dark one of these days :)
Guy
