Internal bearing removal help
iconic944ss
Swingarm linkage bearings on Project Falco have been water damaged and need renewing.
These suckers are only 12mm internal and look to be a swine to get out, so suggestions on removal / replace very welcome.
Only method suggested so far was to dremel the outer edge of the cage away to allow the pins to be removed and let the 'cage' collapse, with a little assistance.
Internal bearing puller was mentioned but I cant find one small enough for the job.
Cheers - frank
How about a picture Frank? Without knowing what it looks like it's like asking a blind man what colour your shirt is :rolleyes:
Cheers - frank
Both methods I have used. just had to Dremel the clutch pushrod needle bearing on the SS. Its tiny, about 10-12 mm and I used the pushrod to get it from the other side once it was distorted enough
Many Thanks Scotty!
I'm convinced this kit is just what I need but, working with the swingarm in the frame is awkward so I've just ordered a kit via Ebay as I'm convinced it will be handy in the future.
In the swingarm section there are two sets of bearings installed next to each other and I've already damaged one outer cage edge trying to tap it out.
Time to wait for the right kit to arrive and do the job right.
Cheers - Frank
NB - This is what I'm working with at the moment:
Thanks very much DrD, your post might well answer an important question for me...
The falco has a different design, straight ending, swingarm but the end that mounts to the frame is quite similar to the RSV. Access is dreadful to the upper linkage bearings (unlike the 'hollow' inside the banana section of the RSV arm).
I couldnt tell if there is an internal flange between the two bearings, preventing me from being able to hammer them through, I'll flush the spot thoroughly now and dig my magnifying glass out to see if I can use your extraction method to gain some time.
As an aside, I bought some EXPENSIVE full compliment bearings from a company recommended on Ridersite:
"Linkage Bearings: Torrington HK1812V. (6 needed for full set) from...
Motion Industries,
Unit 2,
Bracken Trade Park,
Dumers Lane,
Bury,
Lancashire,
BL9 9PE
Telephone: 0161 705 1237
I also thought viton seals would also be good a extra to install to keep damp out but they recommend Nitrile as a better option - not cheap, bearing + seals + P&P = £70
Thanks again - Falco Franco
Yeeee Haaaaa....
Turns out there is NO flange and by heating the area with a hair drier and using a 16mm socket - managed to hammer through the old bearings (but sadly, the puller i ordered isnt needed today). New bearings installed a treat, along with double-lipped seal that works an absolute treat.
Why is there always a down side though?
Thought the dog leg bearings were fine but on trying to add a little grease, some of the needle rollers came flying out :mad:
Good job I have the extra bearings to do a total overhaul.
Many Thanks - Frank
I know that feeling about the needle rollers
- I ran a magnet around my garage collecting them after I replaced the ones on my rsv
I have put caged rollers in for the time being - and completely packed with Rocol Aqua 2 plus some trick PTFE Teflon washers to protect the new seals and centre the dog bone.
