Integrated LED Brake and Indicators
Link no worky, but I get the idea.
Sam, posts on here as "Sam", recently put one on a Monster and got through the MOT without any problems.
Thanks for that, it worked fine when I tested it.
No wonder no-one has replied to my posts, I thought I had become a lepar on the other forum.
Will have a search for Sam.
I think a lot depends on where you.
Some will be road legal ("E" Stamped) and some won't, so you need to confirm this before you splash the cash.
....and you'll find Sam's thread here.
I looked at this type of arrangement for my project bike.
My understanding is if the indicators are integrated where the tail light/stop light becomes an indicator when you signal they are not approved.
I think I saw one where it was integrated but the indicators didn't impact on the tail or stop light. (it was about £200 and was made for the PS)
Whether they would get through an MOT might depend on how clued up the tester was.
You could blank out the lights and just get a daytime MOT though.
I think that by that you mean? - if tail/stop light is not lit while the indicators are on then they aren't approved.
The 907 has tail light and indicators built into the same unit but function separately.
The one I am looking at states this.
"DUCATI LED Rear Motorcycle Brake and Tail Lights with Built in Indicators do away with rear indicators for a fantastic trimmed down rear end.
Clear lens LED rear lights feature LED stop/tail light, plus integral indicator LED's enabling stock indicators to be removed or as an additional safety feature.
May need an LED flasher unit or inline resistors to correct flash rate."
I will ask the question, as I am really keen on this kind of arrangement.
The problem with these units is, i guess that the stop light becomes the indicator.
They might be OK as you'll only have one inicating amber and one lit red when using both, and two lit red when just tail/stop light.
Best bet would be to ask your local MOT guys and see what the official line is, be a bugger to fit them then have to get a retest just because of that.
I see the point, and where the confusion can lie.
Going to contact the suppliers, and get in touch with whoever I am going to use for MOT duties.
Not sure who to use yet.
Booked in for service with Duc Gla when I get home.
Yes that was what I meant. It was perfectly clear in my head when I typed it.:o
The ones shown in the link are either an led tail and stop light OR you can include the indicators.
However from the info there on the link it appears the tail/stop light "disappears" when the indicator is flashing and that is what makes them NOT "E" approved.
However the simple tail and stop light will be ok.
On the other thread I suggested double sided bar end indicators which meant that Tee4 wouldn't need any indicators on the tail and he could use the led stop and tail light only and be fully legal and have a clean rear end.
Known as the Andrex solution! ;) :D
Hold on !!!!!
Stop the press!!!!!
SO you can use the bar mounted double ended (aherm) indicators and not need the rear indicators. Is that legal.
I am only keen on removing the need for the rear indicators. If I can use bar mounted and remove them, THEN I only need the bar mounted.
Have posted pics of the bar end flashummyjig thingies wot tell you which direction your going in, on t'other thread. :)
But on a completely random tangent and while photobucket is loaded, heres a pic or two of me new bullet, picked up Saturday, :D
Been checking and fettling getting it ready for MOT, hence the spanners, screwdrivers and the like littered about before any smartarse comments are made, :p
Hold on !!!!!
Stop the press!!!!!
That's what I was trying to tell you! :p :lol2:
I need a drink! :rolleyes: :D
Check out Ebay and Busters and like as I suggested.
You get chrome or black and different styles but they are visible front and rear and legal.
Integrated indicators in the rear lamp will not pass the mot.mot testers are being told at refresher courses about these lamps.the failure will read interferes with other lamp.last years failed a traffic police guys bike for the integrated rear lamp ,when he brought it back for retest he had checked the lighting section of the road traffic act and said it was illegal. Even though his was e marked
Hold on !!!!!
Stop the press!!!!!
LOL, yes, as 239 says, to be legal the turn signals have to be visible from both the front and rear of a vehicle, a car could have a light bar with indicators for example, same principal but a bit more naff looking, :)
monster_998 said:
I knew you were a "Wheel Nut"
Wondered what you meant for a second, you mena the Skye wheel nuts right?
Yes, i'm on there but infrequently, it's generally a bit quiet and trike obsessive, I don't quite get the trike thing, some good fun guys on there though.
Brilliant lads, thanks a lot. Damn shame about the e rated integrated's, would have looked the nuts.
Mike s - loving the Enfield, many a happy and unhappy journey in one around India in 2001/2002. Some adventures on the 500.
Strange interpretation! As long as the other lamp remains lit, doesn't flash or alter in brightness it's not being interfered with.
The MOT tester manual says:
Information
This inspection applies to: all machines except those which either have no front or rear position lamps or have such lamps permanently disconnected, painted over or masked that are:
. only used during daylight hours, and
. not used at times of seriously reduced visibility
If this situation occurs the machine presenter should be issued with a VT32 (advisory notice) recording the above.
Method of Inspection
1. Operate the direction indicators on each side in turn and check the colour, flash rate and is not obscured. Check that the illumination of the indicators is not affected by the operation of any other lamp. Each Lamp must emit an amber light, except vehicles first used before 1 September 1965 where both front indicators may be white and both rear indicators red.
Note: At least 50%
of light sources within a lamp must illuminate
2. Operating the indicators see that the operation of each front indicator is readily visible from the riding position or that the 'tell tale' is operating correctly.
Reason for rejection
1. A direction indicator
a. missing or obscured.​
b. does not show a light of the appropriate colour​
c. not working or not flashing at 60 to 120 flashes per minute, or which is affected by the operation of another lamp.
2. A "tell tale" does not function or operate correctly.
Note: if the indicators can be seen from the riding position there is no need for a "tell tale" to operate.
However, from the Construction & Use Regulations;
6.3. Direction indicator lamps
6.3.1. Two per side.
6.3.3.1.2. The distance between the inner edges of the illuminating surfaces of the rear indicator lamps must be at least 180 mm.
6.3.3.2. Height: minimum 350 mm, maximum 1 200 mm above the ground.
6.3.3.3. Length: the distance towards the front between the transverse plane corresponding to the extreme longitudinal rearmost extremity of the vehicle and the centre of reference of the rear indicators must not exceed 300 mm.
6.3.6. May be grouped with one or more lamps.
6.3.7. May not be combined with any other lamp.
6.3.8. May not be reciprocally incorporated with another lamp.
6.3.9. Electrical connections
Direction indicator lamps must switch on independently of the other lamps. All direction indicator lamps on one side of a vehicle must be switched on and off by means of one control.
So although such indicators may not comply with the Construction & Use Regulations they should NOT fail an MOT, but as always these rules are open to interpretation,
Hmm,
This is an interesting one.
I have the LED version of the just the brake light and have never had an issue with MOT's strange given the lens has an e-mark, but I'd doubt that the actual circuit board, LED's etc are approved nor would I think the MOT inspector would think to look.
So, I can't see an integrated tail/brake/indicator unit being an issue. Reasons being;
1. With lights on, you have two separate tail lights
2. You have separate left and right indicators
3. With the indicator on, (left or right), the opposite brake when used would be lit bright!
It covers all the functioning options.
Just take a look at most of your new cars these days - all have indicators/brake lights in the same light unit, some with the brake/indicator unit adjacent to each other. Look at a mini for example!!
Are there any documents out there issued by our fantastic Government that give guidance on light arrangements for bikes?
I have an integrated set on my Monster and it passes its MOT ok. MOT station is on the South Side of Glasgow
The conflict between "Contruction and Use" and what is allowable on an MOT applies in several areas.
You don't require a speedo for an MOT but if used on the road you must have one for C&U.
The perennial problem with exhausts arise in that what markings are on and allowed by an MOT are at variance with C&U and even noise emitted is subject to limits for C&U but for an MOT it has to be "not excessively noisy".
Seems a nonsense that you can leave an MOT station with an "pass" and get pulled 2 minutes later by the Police and pick up points/fines/ASBO on the same vehicle.:confused:
I think the sticky area for this one, unlike car light clusters, is that the indicator directly replaces the brake light on that side, where a car cluster has a seperate light whether it's in the middle of or encircling a brake light or directly next to or below/above.
Another thing i'm unsure of, isn't there some directive that specifies direction indicators have to be a set width apart?
With the combined tail-light you could see the potential for blurring and confusion of intended direction, especially so if the brake or sidelight wasn't switched on at the time of indicating.
From the C&U regs quoted above:
about 6"
3. Are they visible enough?
No, but that is just my opinion.
The whole point of indicators is that they should be clearly visible.
If a flashing light unit is set apart from other light sources then your eye will pick up the signal more easily - (no light,100% light, no light...). If the same flashing light unit is set inside another source of higher (and/or similar colour) light output then your eye and brain has to work harder to process the difference in the signal - (some light, some other light., some light...), etc.
Some installations are doubly unsuitable as they are not visible from the side of the vehicle, eg older monsters, 916.
