ian900ss
Thought I would share my experience with a cheap mod you can do to improve starting on the SS. Sorry if this has been covered before (I am sure it will have been somewhere)
I have replaced the cable from the battery pos to the starter relay and the one from the starter relay to the starter with 16mm cable (quite chunky). I also put a short 16mm link from the battery neg to the frame.
Bike turns over better and usually fires on the first push. Mod simply allows more amps through. It cost less than a tenner, took under an hour to do and I highly recommend it as the standard cables are a bit weedy.
Curriedug, I will get yours done soon after the Aprilia! :thumbs:
