ignition problems
aircooled
i am not geting a spark at the horizontal cylinder, this happen on my way home from work today, so far i have checked the I C U,s by swaping them over, problem remained the same which says to me I C U,s are OK. i now want to check the ignition pick up coils and ignition HT coils, what i want to know is can i, without causing any damage, swap the wires from the ignition pick coils from one I C U to the other to eliminate or prove the fault is with the pick up coils, and then do the same with the ignition HT coils if needed i am concerned that by doing this i could damage something
cheers frankie
Dont swap - check your pick ups with a multi meter.if one is fkd it will read either infinate or zero resistance
