Ignition cutting-out due to lights!!!!
SS_al
Folks,
A wee brain-treaser has developed with the Ignition/light unit on my SS. Spoke to Chaz at Ducati Glasgow - he couldn't be any help.
Whats happen:
1. Ignition key in - turn ON, injector whirl up - no problem.
2. Press ignition button - engine fires-up - no problem.
3. Flick sidelight/headlight switch to ON - Engine cuts out.
also:
2. Flick sidelight/headlight switch to ON - lights on dash go dead.
3. Press ignition button - nothing happens.
The problem is intermitant - it doen't happen every time, and after the engines been running for a couple of minutes the lights will switch on without cutting the engine.
Possible causes/solutions listed so far:
Dodgy connection somewhere - check all connections.
Dodgy battery connection - Checked connections already - no problem
Moisture trapped in starter unit - check unit, clean etc.
Battery not charging properly - check charge
Anyone had a similar problem - or know how to fix it?
Al
used to get a similarish problem on lambrettas when they had a demagnatised stator plate/flywheel. but that info will be absolutley no use to you ;)
Not really too bothered - as long as I can sort it for it's MOT on saturday.....
OH FECK - I feel a major stripdown, fettle and clean coming on for the beast.
just got my first MOT done on Friday, passed flying colours thank goodness.
yea strip it down and check all the connections.
/ian
Just thought what it might be...........
LED tail-light with integrated indicators - need to remove/stop the indicators and put standard one on for the MOT anyway.
Here's hoping...........
