I need some relief...oil relief
ian900ss
Derek recommended ST2 cases to replace my 900 cases whichneed a bit of work, so I have a set. Theres a little diffence internally but they seem to be pretty much the same for the most part. There is however, no oil pressure release valve as per the pics. I could make it work by manufacturing a plug and tappig the cases. Can anyone offer some sound wisdom on whether I will encounter problem using these cases?
So the first two images are the 900 case and the second the ST. The wierd round bit doesnt have any oil passages etc so I dont think thatll make any difference, its like a baffle of some sort so the only diffence I can see is the lack of pressure release. Is it even essential that I have it?
I hadn't foreseen this but it has come up before. Sometime around about 1998 the oil pressure switch was moved to the oil pump. There are even some bikes from late '97 / '98 with both oil pressure relief valves. One in the pump and the other in the LH crankcase half. If there isn't a valve in your pump you might be better to fit a later one. Any should fit from SS/Monster/748/996/ST etc as long as it is after '98.
Early pump
Crankcase with oil pressure relief valve
Late pump
Cool Derek, will do. Can you see any other issues with the slightly different cases?
Does the hole need blocked up then?
If you fitted a later pump with a built in oil relief to an early SS you could block off the one in the crankcase. If you use a later crankcase with a late type pump you shouldn't have to do anything else. I think Serious Black had something to say about this a few months back.
I did a little research and seems the cases changed in 1996 not 1998. And the strange round bit in the 2nd picture was a casting to take the kickstart boss that was fitted to the Cagiva Dakar Elefant.
might be able to help you out there...
any good to you ? from a 2001 900 SS
