I was changing a clutch slave cylinder last night and used a technique I've been meaning to pass on for some time.
Any of you who have worked on hydraulic systems, be it clutch or brakes will be familiar with what happens when you undo the slave cylinder or brake caliper and fluid continues to dribble out of the disconnected brake pipe, making a horrible mess and allowing air into the line which can be subsequently difficult to bleed out.
The answer is very simple. Loosen the bleed nipple and attach a plastic hose leading to a jar. Pull in the lever once and hold it there. Then wrap an elastic band round the lever and handle bar to keep the lever held in, or use a cable tie or a bit of string or whatever else is convenient. With the lever held in, the passage back to the reservoir is blocked off, so no fluid flows from it and out the other end. This leaves you free to disconnect the slave cylinder or caliper, do what ever work you have to do and then fit it back together with very little spillage of fluid and a minimum of air in the system which will easily bled out.
You can apply this method to cars just as easily by using a brick or a length of wood to hold the brake/clutch pedal down.
